K-R42 - wasser firmware - JB Android 4.2.2
    Originally posted by polly69 View Post
    Im running mine through a Amp and have no issue at all its been working fine, although i have the same issue with XBMC as ive had with every version the audio in settings theirs a error for my amp and when i change to HDMI i get static white noise i have to leave it analogue its also unwatchable anything streamed from my NAS drives but it was all the same with the stock FW.
    Sorry, but I'll be very happy for clarification...
    a. Do you mean that when using analog (the S/PDIF TOSLINK) it works fine?
    b. What about the AV out stereo audio? Does it work for you?
    c. I'm going to get my k-r42 box next week, and I read all posts here and in xda-developer. To be honest, I'm more than confused... Can I ask your kind advice which FW to install (Wassar's, with or without the new kernel, lewy20041's Hybrid or justxbmc)...
    I'll be using it to watch movies from XBMC + via ethernet from a remote PC (Movies can vary from 720p to 1080p).
    Will be wired to an amp with 5.1ch (via s/pdif) + in other cases hooked to 2.1ch speakers (via AV-out).
    Will need the ability to browse the internet.
    Play Store to download occasional games and apps.
    It will be hooked to a mini-projector.
    Very sorry again for my a-bit-long post... regards!
      No sound
      I also flash the kernel and I had no sound, I saw that the device starts with the volume to "0", turned up the volume and perfect. No tv volume, the volume of android.
      K-r42 box with 2.0.4 Lewy20041
      Out: TV LG HDMI
      In: original controler/mini keyboard trackball controler wifi
      XBMC Nightly build v13
        k-r42-wasser-1.2.1 firmware test
        Hi guys!
        I have been testing k-r42-wasser-1.2.1 firmware for about one week.
        My device has V.2.1 board inside and it was tested with the three different 1080p kernels by wasser.
        Tested with 5V 4A PS(No stock).
        Here are my results.
        1) Kernel which is included in wasser's firmware:
        -Ethernet works just in case wifi is switched off manually. There isn't error for RX traffic in log.
        -Wifi works properly when Ethernet is switched off manually.
        -HDMI video/audio O.K.
        -Harware and software Power button works properly with stock remote and T2 Airmouse.
        -I can stream from Internet big sizes movies (30GB+, biggest was 57GB) w/o stuttering by using MX Player Pro(HW+) with custom codec.
        -When I use MX Pro with HW(NO+) decoding, it allows me to have multi channel 5.1 sound via SPDIF(ROCKCHIP-SPDIF PASSTHROUGH), all kind of AC3, DTS, DD. It's perfect for playing local (USB HDD) movies. Concerning streaming movies from Internet by using HW, there is some restriction of bitrate (Up to 19-20Mbps).
        -AnTuTu(V.4.0.4) scores are about 19000. Processor hardly warm.
        But, device reboots time to time. Can play 1 hour, reboot, then 30 min, reboot, 2 hours, reboot, etc.
        2) Kernel "[email protected]#30 from Nov 1 2013" (I took this "kernel-k-r42-1080p-011113.img from here https://skydrive.live.com/?cid=42722...7BE5EAF8%21103):
        -The absolutely same features as position#1.
        But MUCH LESS reboots.
        3) Last wasser's kernel from here http://www.freak-tab.de/wasser/kerne...2.1-111113.img :
        -Doesn't allow me to switch an Ethernet on at all.
        Didn't any test with it because is uselees for me w/o LAN.
        I will be glad to see your own results with THESE hardware-firmware combinations.
        Good luck!
        CS918II/16GB(HTC-031-V1.0 board)
        CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
        K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
          @digger
          thanks for so much experimenting. I suspect I have the newest board also, considering I just received it from geekbuying and because i had no lan when first using the latest justxbmc. I haven't tried using any other firmware other than justxbmc, but I did flash wasser's latest kernal (11/11?). that fixed ethernet for me, but for some reason I have no audio on the actual tv the box will be plugged in to. I experimented last night and found that my living tv plays all the audio fine. This combo of justxbmc and wasser kernal would work for me if i was going to use the living room tv, but its going to be plugged into my daughters tv.
          I've stuck with JustXBMC cuz that's what she will be using the majority of the time. Have you tried the combo I used?
            BTW: can you explain the different and/or do you have a link?
            RK3288 Devices
            - Overview BOX (LINK !)
              Sorry, buddy,
              It will be too difficult for me to explain all the difference you ask me about if you have never used MX Player before. One thing I can tell you, it is the best player for me after more than one year playing with Android based sticks/boxes. You can take some detailed information in forums which are dedicated to this excellent application, but my suggestion with the links won't be suitable for you, because I'm a Russian speaking person and use my local language forums as sources.
              Good luck!
                Hi guys!
                Good luck!
                Hi Digger, thanks for excellent reports
                it's on my todo list for next kernel/firmware update.
                  Originally posted by franckleroy View Post
                  May be for better network performance you should increase theses buffer size to something like :
                  net.tcp.buffersize.default=10240,87380,256960,10240,87380,256960
                  net.tcp.buffersize.wifi=10240,87380,524
                  288,10240,87380,524288
                  or 512k for both :
                  net.tcp.buffersize.default=10240,87380,524288,10240,87380,524288
                  net.tcp.buffersize.wifi=10240,87380,524288,10240,8
                  7380,524288
                  I used a trick in order to not display extra spaces ;-)
                  I also find some large buffer config for android :
                  net.tcp.buffersize.default=6144,87380,1048576,6144,87380,524288
                  net.tcp.buffersize.wifi=524288,1048576,2097152,524288,1048576,2097152
                  Franck
                  have you noticed any improvement here?
                    Originally posted by dzidek View Post
                    I've flashed kernel with Your rom, and ...
                    ETH works
                    justXMBC.apk/XBMC Frodo works
                    WiFi works
                    Edit:
                    But You have to fix audio! There is no audio on HDMI, S/PDIF, analog No matter XMBC or pure sound from system!
                    Also suspend/resume problem is back ;( "Software" suspend from system bar doesn't work - only from oryginal IR remote, but after this resume is imposible! Both IR remote and "hardware" power button not responding :|
                    Summary:
                    • ETH + WiFi works great
                    • justXMBC.apk plays flawlessly
                    • no audio
                    • sleep/resume problem
                    - audio issue is now fixed, it will be released at the weekend
                      Sorry I cannot make anymore test at the moment as I have upgrade my windows to 8.1 and rockusb driver doesnt work any more
                      I will take an old laptop from my company to continue flashing and testing...
                      I have exactly the same issues as digger on my jesurun PCB 2.1.
                      I have just received 2 k-r42 from geekbuying, I'll try to do some more tests this weekend.
                      Franck.
                      Hey digger this is my skydrive account ;-)
                      for windows8.1 drivers fix follow this.
                      Jesurun v2.1 old rev with wasser firmware 1.2.5
                      K-R42 v2.1 new rev with wasser firmware 1.2.5
                      Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
                      Minix neo s8s with stock firmware
                      Plex streamer with external MX player
                      TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
                        Originally posted by jhr1948 View Post
                        @digger
                        Hi jhr1948,
                        I can't help you with my experience of using JustXMBC. I haven't tried this firmware for my CS918, because my conclusions from past time had persuaded me that if I don't use XMBC, I always can reach all the needed media content with at least 20% less clicks. Try to flash wasser firmware which has XMBC onboard and I'll try to answer all your questions
                          Hi wasser,
                          Sorry, if I answer the question which wasn't addresed to me, but I tried to utilise these changes were suggested by franckleroy(Frank, thank you very much for your help and your skydrive too). I didn't see any visible improvement, unfortunately. This may be present, but we can't catch it with eyes, but with the some special tests or logs only.
                          And thank you for your possitive words regarding my test. If you want me to help you I'll do my best if I can.
                            I also have good working kernel from the 1.2 your rom, there is almost no reboots(device nort warm,Because I made the cover of ventilation at the top), the last kernel 111113 works for me very badly the system can not boot persistent errors
                            k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
                            rom 1.0.4 (kitkat) old revision Wasser
                              So... first try, first problem:
                              Code:
                              18:00:29 328    Load Setting ok
                              18:00:29 359    Finless ROM Flash Tool v1.3.7.0 Start Run
                              18:00:29 359    Scan thread:4504
                              18:00:29 375    ProcessID:6520,ThreadID:5816,RefCount:0
                              18:00:29 375    ProcessID:6520,ThreadID:4504,RefCount:0
                              18:00:29 390    Info:(thread=6732)IoControlProc-->DeviceIoControl In
                              18:00:29 406    Info:(thread=6732)IoControlProc-->DeviceIoControl Out,ret=1,err=183
                              18:00:29 468    Info:(thread=8100)IoControlProc-->DeviceIoControl In
                              18:00:29 468    Info:(thread=8100)IoControlProc-->DeviceIoControl Out,ret=1,err=183
                              18:00:29 468    Info:(thread=1196)IoControlProc-->DeviceIoControl In
                              18:00:29 468    Info:(thread=1196)IoControlProc-->DeviceIoControl Out,ret=1,err=183
                              18:00:29 515    Info:(thread=6392)IoControlProc-->DeviceIoControl In
                              18:00:29 515    Info:(thread=6392)IoControlProc-->DeviceIoControl Out,ret=1,err=183
                              18:00:32 890    INFO:Start to erase NAND
                              18:00:32 890    INFO:Start to lower format
                              18:00:32 906    ERROR:LowerFormatDevice-->RKU_TestUnitReady failed,subCode(0xfd),Errcode(-1)
                              18:00:33 906    ERROR:LowerFormatDevice-->RKU_TestUnitReady failed,subCode(0xfd),Errcode(-1)
                              18:00:34 906    ERROR:LowerFormatDevice-->RKU_TestUnitReady failed,subCode(0xfd),Errcode(-1)
                              18:00:35 906    ERROR:Lower format failed
                              18:00:35 906    ERROR:EraseIDB-->GetFlashInfo failed
                              18:00:35 906    ERROR:Erasing IDB failed
                              someone have an idea?
                              I have edit the hole configuration column "path"...
                              ""Found RKAndroid Loader Rock Usb" is showing...
                              BTW: My stock bootloader seems to be 1.20 (because of "cat /proc/cmdline" => "...bootver=
                              2013-05-18#1.20...") ...???
                              FIXED:
                              - deinstall / install driver (more than 1 time because want to get 3.0 instead 3.5 but seems so it's the same version???)
                              - use another cable
                              Suddenly EraseIDB works....
                              Than I got:
                              ERROR:Test device failed
                              ERROR:Run failed
                              two times, than deselect the bootloader and 3. try it work...???
                              RK3288 Devices
                                Hello,
                                I'm trying to flash wasser's firmware but at first boot I get stuck with the CWM recovery menu. Which "parameters" file should I use? There are four: parameter, parameter8, parameter10 and parameter14...
                                Thank you for your help!
