K-R42 - wasser firmware - JB Android 4.2.2
    Originally posted by wasser View Post
    Of course any finding helps me a lot. thanks digger!
    Do you have k-r42 revision 2.1? if yes does ethernet work for you?
    it seems some user still have problem with ethernet. sadly i don't have have to test it.
    thanks
    Yes, wasser, I have k-R42 revision 2.1 and Ethernet works for my device.
    I have just found another quite strange thing. There is some bugs with mutual influence between Lan and WLAN hw modules.
    Please look at picture which is bellow.
    Probably something wrong with algorithm of switching on and off of the wifi or ethernet mudules.
    CS918II/16GB(HTC-031-V1.0 board)
    CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
    K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
      Originally posted by Flumpster View Post
      A quick note about your download link mate.
      Even tho your link says K-r42-wasser-1.2.1.zip when you actually click it then it downloads T-r42-wasser-1.2.1.zip
      If I change the link manually to http://www.freak-tab.de/wasser/k-r42-wasser-1.2.1.zip then I get the K zip.
      Have you got this wrong mate?
      it's my typo bug! and it's fixed now. Thanks for your feedback!
        [ATTACH=CONFIG]3905[/ATTACH]
        i only see the network traffic errors by eth0. It's a know bug in firmware, sadly we don't have source code.
          Originally posted by dzidek View Post
          I've flashed new rom to my K-R42 (v2.1).
          Small comparison wasser's rom to chinese rom (from previous, latests links):
          - slower WiFil; bandwidth decrease (in tests) from 7.5-6.7Mbps to 3.1-2.6Mbp;
          - ETH is not working (same packet lost like in Lewy's rom);
          - wallpaper is really nice;
          - sleep works the same but resume is better - with standard IR remote works every time;
          - increase score in AnTuTu from 17327 to 19752
          I'm going to fllash back chinese rom because both WiFi and ETH works perfect! Moreover justXBMC and XMBC "Frodo" works too!
          could you please check if you have downloaded the correct firmware? it should be k-r42-wasser-1.2.1.zip.
          The download url was wrong! It's my typo
          thanks
            thanks
            Dzidek downloaded the correct firmware.
            He changed manually path link from t to k letter and he got a correct firmware. Two people (included dzidek) on Polish forum tested this firmware (both of them have correct links) and they had problem with ethernet.
              have you tested ethernet with k-r42-wasser-1.2.1 firmware? It's trange why ethernet doesn't work for someone here!
                could you please post the dmesg log and lsmod log please?
                thanks
                  Hi wasser,
                  You haven't noticed something important except the log errors in picture was provided by me. There are two icons for wifi and Ethernet having BLUE COLOR AND WORKING SIMULTANIOUSLY.
                  May be this bug is somewere in config, isn't it?
                    OK, when I back home I'll send You
                    One more observation - looking at net switch, LED indicator for the port where K-R42 is connected behaves "strange"
                    - WiFi on + ETH off = LED off
                    - WiFi off + ETH on = LED on/flash
                    - WiFi off + ETH off = LED on/flash
                    dzidek
                    K-R42 PCB 2.1
                      Sorry,wasser,
                      I still haven't found the time to flash it. I have your last t-r42-wasser-1.2 FW with your last 1080p kernel for K-R42 from 2nd of Novemer being instaled. All the my information is based on this my configuration.
                      Have you made some important changes among the t-r42-wasser-1.2 and k-r42-wasser-1.2.1 firmware except of removing BT in the settings(if you actually do it)?
                        Wasser, how about changing approach to figure out a ETH problem?!?
                        I will connect my K-R42 PCB 2.1 to my PC and give You access through TeamViewer (I have full version)!
                        With this "hybrid" You can easily access K-R42 and with adb shell get whatever You want from it!
                        Another words: with TeamView You will get access to my PC and then, with adb shell straight way to K-R42
                        Moreover, with this "connection" You can easily upload new kernel/rom, flash it and test! Witout waiting for us - testers!!
                        So, are we going to setup online, debug session??
                        dzidek
                        K-R42 PCB 2.1
                          Hi mates,
                          is the a manual to explain how to flash wasser fw, this is not a all-in-one img ?
                          I tried to flash with RKAndroidTool, but on boot there is a recovery error about mounting recovery/log...
                          Please help !
                          Franck
                          for windows8.1 drivers fix follow this.
                          Jesurun v2.1 old rev with wasser firmware 1.2.5
                          K-R42 v2.1 new rev with wasser firmware 1.2.5
                          Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
                          Minix neo s8s with stock firmware
                          Plex streamer with external MX player
                          TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
                            Originally posted by franckleroy View Post
                            Hi mates,
                            Please help !
                            Franck
                            finless tool 1.37
                            k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
                            rom 1.0.4 (kitkat) old revision Wasser
                              Originally posted by pes1313 View Post
                              finless tool 1.37
                              thanks, and it is provided in fw zip...
                              But still the same error message a boot time within recovery about invalid command argument : cant mount /cache/recovery/log ...
                              So I erase cache partition and reboot and seams ok...
                              Franck
                                dzidek
                                the next kernel update will have a fix for this issue and i will upload the new kernel soon. I need someone who have k-r42 revision 2.1, for testing.
                                thanks
