K-R42 - wasser firmware - JB Android 4.2.2
    Hi Digger,
    you don't need to make screenshot, just post the output of ifconfig in ascii is enough ;-)
    could you please post the dmesg log? to get dmesg.log just do
    dmesg > /sdcard/dmesg.log
    Questions:
    1 How did you flash the 1.2.2 firmware? with RKAndroidTool.exe?
    2 did you flash the boot.img from 1.2.2 firmware?
    thanks
      Originally posted by wasser View Post
      Hi Digger,
      Questions:
      thanks
      Dear wasser,
      Screenshot...
      Nevertheless, I made it and sent this picture to you yesterday, you can look it over and all RX mistakes are visible
      Dmesg...
      What would you prefer I have to switch on or off before making the log file?
      Answers:
      1. Yep, I flased your last version 1.2.2 firmware using RKAndroidTool.exe Ver.1.37, which was included into your firmware package.
      2. I flashed all the img.files and parametr "0" using your default setting, any changes had been done. Of corse, I apllied IreaseIBD too.
      Have a nice day!
      CS918II/16GB(HTC-031-V1.0 board)
      CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
      K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
        Originally posted by digger View Post
        Dear wasser,
        Screenshot...
        Dmesg...
        Answers:
        Have a nice day!
        Hi Digger,
        for dmesg.log i prefer reboot the box before make log file
        thanks
          Originally posted by pes1313 View Post
          for me, only works well for the old firmware revisions , but I opened my k-r42, my revision of the board v2.1
          it would be great if you could please post some results to 1.2.2 firmware.
          does sleep/suspend work correct now?
          how about stablity?
          fullhd video playing?
          wifi/ethernet?
          thanks
            Hi Digger,
            thanks
            Please have it:
            dmesg.log.txt
              how about stablity?
              wifi/ethernet?
              thanks
              Hi Wasser
              ALL works correct me , BUT but I have not tested the ethernet,
              Wifi works good
              I launched video 36 gb mkv works smoothly
              ,and There is one moment when switched to sleep last night , in the morning I saw that the TV box works (blue light),Watch for them for inclusion in a few hours, it may incidentally
              I will continue to check if I will see what kind of bug will write,
              Thank you so much Wasser, ROM is great
              P.s Can be in the next version of Rom, add "usb safe remove" in storage setting ,it would be cool
              k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
              rom 1.0.4 (kitkat) old revision Wasser
                Please have it:
                [ATTACH]4002[/ATTACH]
                thanks for the dmesg log. it looks a little bit strange because i don't see ethernet connection in dmesg. is your box connected to lan?
                  Certainly LAN is switched on. I can stream video from the Internet without any problem. But there is one strange thing, when I launch Speed Test apk, it can show me the "0" outgoing speed, then normal, then "0" again, etc., isn't any rules.
                    PCB v2.1 doesnt implies new or old revision.
                    I think it depands on a date.
                    I have 3 PCB v2.1, the old one only accept old revision, the 2 new ones only new revision.
                    My old PCB v2.1 is dated may 2013, not yet openned the 2 new ones but I suspect earlier date.
                    Franck.
                    for windows8.1 drivers fix follow this.
                    Jesurun v2.1 old rev with wasser firmware 1.2.5
                    K-R42 v2.1 new rev with wasser firmware 1.2.5
                    Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
                    Minix neo s8s with stock firmware
                    Plex streamer with external MX player
                    TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
                      My is dated 2013/05/31 but there is another information too, that Gormar means it is possible YearWeek ...
                      Perhaps it depends on that?
                      RK3288 Devices
                      - Overview BOX (LINK !)
                        I'll check the date of birth of my 3 devices when I'll be back at home by the end of the week...
                        Franck from London...
                          ... but what's about "(Overall) bit rate" and "Format..." and "Original frame rate"?
                          If you use Windows you can use MediaInfo Lite via context menu (right mouse button)...
                          RK3288 Devices
                            enjoy London
                            RK3288 Devices
                              Originally posted by lefizz View Post
                              OK after deleting the cache partition and waiting for a 5 minute reboot it eventually went into android Yipee!!!
                              First things first this rom doesnt have XBMC installed, where can I first the right version for the RK3188??
                              Oh, and thanks for all the help. Much happier with my new purchase now, oh and ethernet is working which is great.
                              Thanks a lot
                              you can get it from www.xbmc.org. However i will readd xbmc into next firmware if more users are interessed!
                                I'd like it, too, as in v. 1.2.1 "preinstall xbmc with passthrouh"
