K-R42 - wasser firmware - JB Android 4.2.2
    Wow, my box is really fast now! Great work!
    Minor issue:
    My RC11 keyboard works for 90%. For instance: Enter--> q. As reporter above.
    Keyboard is not working in recovery.
      I'm running my R-K42 with the stock ROM from the factory. When people upgrade their ROMs and say that the box is running much faster, what are they referring too? Is it the UI that is more responsive, or a higher score in a benchmark test? I know many members here use the box for XBMC and are concerned with 1080p playback, but I am happy with 720p.
      I am interested in getting the best HTML5 performance out of the box. Would installing Wasser's or Lewy's Rom help?
        Basically everything is more snappy.
          Originally posted by curlyboi View Post
          I am still having problems with TV OUT in 1.2.3
          I have a projector and old CRT TV. The projector is VGA so I am using HDMI2VGA adapter from dealextreme, which is working great. The projector is 720p so that's the max resolution the box allows me to set and I am happy with it.
          BUT: No matter what I do, I can't get a good picture with the TV OUT. When I start the device, the TV is blank. If I enter system settings, and switch the TV format from PAL to NTSC (and optionally back again to PAL), I get a picture, however, it is very distorted. I think the RGB color layers are offset and floating apart. Also, the picture is only stretched this way in the bottom half of the picture, the top remaining blank.
          I tried disconnecting the HDMI, which didn't make any difference. When I connected it back, the TV OUT went blank again and was only enabled again after switching the TV format to NTSC and back to PAL again.
          I need both outputs to work simultaneously, e.g. I can watch something on my projector and my gf watch the same thing when she has to do something in the other room with the old TV.
          Please help?
          Lewy's 2.0.4 worked good with this with some of the newer wasser kernel...
          please try to set video.accelerate.hw=0 in /system/build.prop. it should work again
            Originally posted by vipersvcd View Post
            Hi Wasser
            There is some strange IR remote behaviour some time ,
            It seem the key preses are duplicated or the a key acts like its stuck ,
            I see there is a IR remote fix.zip in the T version of the firmware ,
            Is this relevant to this firmware too ?
            you don't need remote fix.zip if your firmare has version 1.2.3. it's made for old firmware.
            I cannot reproduce this issue
              Originally posted by HatNet View Post
              Hi wasser the K-R42 does not have build-in Bluetooth but can i use Bluetooth dongle ?
              if i can how can i make it work? thanks.
              ATM Bluetooth dongle is not supported in my firmware. It's on my todo list for next firmware
                To wasser
                Pls recheck recovery in firmware.
                Can you add a normal one from http://www.freaktab.com/showthread.p...ery-for-rk3188
                CS918(old wifi)+Air Mouse ea-01
                Out: TV LG HDMI (1 day a week AV out Samsung Tv)
                CX919(wifi ap6210)+Mele F10
                Out: TV LG HDMI
                  Originally posted by wasser View Post
                  oc kernels
                  kernel-k_r42_new_revision_cpu1704_ddr720_1080p_gpu600h
                  kernel-k_r42_new_revision_cpu1704_ddr800_1080p_gpu600h
                  kernel-k_r42_new_revision_cpu1800h_ddr720_1080p_gpu600h
                  kernel-k_r42_new_revision_cpu1800h_ddr800_1080p_gpu600h
                  kernel-k_r42_new_revision_cpu1920h_ddr720_1080p_gpu600h
                  kernel-k_r42_new_revision_cpu1920h_ddr800_1080p_gpu600h
                  kernel-k_r42_old_revision_cpu1704_ddr720_1080p_gpu600h
                  kernel-k_r42_old_revision_cpu1704_ddr800_1080p_gpu600h
                  kernel-k_r42_old_revision_cpu1800h_ddr720_1080p_gpu600h
                  kernel-k_r42_old_revision_cpu1800h_ddr800_1080p_gpu600h
                  kernel-k_r42_old_revision_cpu1920h_ddr720_1080p_gpu600h
                  kernel-k_r42_old_revision_cpu1920h_ddr800_1080p_gpu600h
                  version 1.2.3
                  - all revisions support
                  (you have to choose the correct one)
                  - wifi support
                  - ethernet support
                  - init.d support
                  - 1080p24hz, 1080p30hz, 1366x768p60hz support
                  - frame skipping fix for video play
                  - rooted
                  - ntfs, nfs, iso, cifs filesystem support
                  - 40% like performance boost
                  - preinstall es file manager, xbmc
                  - new kernel, improve sleep/suspend, stability
                  - support static ethernet mac adress
                  - passthrough support in xbmc
                  - fixed lan rx network traffic
                  - fixed bug in formating the NAND Flash, sdcard is mount correctly
                  - fixed tv-out bug
                  Link download:
                  1.2.3 firmware for k-r42 with OLD REVISION
                  1.2.3 firmware for k-r42 with NEW REVISION
                  version 1.2.2
                  - wifi support
                  - ethernet support
                  - init.d support
                  - rooted
                  - new cwm recovery image
                  - fixed key mapping issue
                  Link download:
                  1.2.2 firmware for k-r42 with OLD REVISION
                  1.2.2 firmware for k-r42 with NEW REVISION
                  version 1.2.1
                  - wifi support
                  - ethernet support
                  - init.d support
                  - 1080p24hz, 1080p30hz support
                  - rooted
                  - preinstall xbmc with passthrouh support, es file manager
                  - fix for network traffic
                  - new kernel, sleep/suspend works better now
                  - boot-720p and boot-1080p images
                  Link download:
                  Be aware: it is your own risk!
                  Installation info:
                  1. run RKBatchTool--1.7.exe tool which is included in the zip file to flash the firmware
                  2. select the firmware image then click restore button to
                  flash the firmware
                  please post your feedbacks, it's very important! and don't forget to report the firmware version you flashed, the revision of your k-r42!
                  - thanks to lewy for the modded xbmc
                  - thanks to minix for the firmware
                  Anyone can tell me how should i differentiate between "OLD REVISION" and "NEW REVISION"? I don't know which one is the correct firmware for me.
                    kikat, android 4.4 for K-R42 (old revision)
                    Hi all,
                    i uploaded new firmware based on kika android 4.4 for k-r42 (old revision). You can download it from here:
                    enjoy!
                      this is cool
                      p.s Wasser great thank you for 1.2.3 firmware , this firmware absolutely stable and perfect for me
                      k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
                      rom 1.0.4 (kitkat) old revision Wasser
                        I am not positive, but according to Digger in another thread...
                        "It is impossible to say correctly that 2.1 is newest. I have v2.1 too, but I had to flash it with 1.2.3 Old version FW. It depends on the date when your box was cooked in Chinese factory. My was born on 1332 (32nd week). And I know 1335 (35th week) requires New 1.2.3 FW. So if your device is with v2.1 printed on board try to check and compare the date of manufacture. Lower than 1332>Old FW, bigger than 1335>New FW.
                        In case you flash wrong FW version, you won't have LAN in working condition only. "
                          Blue ray images
                          Hi Wasser, I saw in the folder "mnt" folder "blu ray" , means possible as that blu ray images watch ?if yes then how to do it with usb hdd?
                            that helped only partially - the image is now displayed correctly, but only in lower left part of the screen, the other remains black. it also lags massively and with reduced framerate - my guess is around 10 fps, maybe less.
                            edit: it also broke XBMC HD video playing (no picture, only subtitles). edited it back, rebooted and it works again. note that i have only enabled libstagefright as mediacodec crashes for me in some videos. using xbmc gotham alpha 10.
                            anyway: how do i permanently remount that storage for r/w?
                              With an init.d script
                              using the remount
                              RK3288 Devices
                              - Overview BOX (LINK !)
                                Thank you wasser, im running this firmware now with the old version and everything runs perfect, LAN works flawless, machine runs smooth.
                                i added a init.d script for mounting my network and works like a charm.
                                DTS Passthrough is working very good, havent got any problems yet and beautifull sound coming from the speakers !!
                                Only thing i experience now is that justxbmc crashes now and then, but video's play smooth as hell !
                                i keep this rom running on the box for sure !
                                Home Cinema Setup Livingroom:
                                50" Panasonic Plasma - CS-X806 (s802 1gb/8gb) with Mele F10 on OpenElec 5.0.3 with Kodi - Pioneer Receiver - JBL Surround System - 4TB NAS
                                Bedroom Media Setup:
                                32" Philips LCD -
                                KR-42 wasser rom
