K-R42 - wasser firmware - JB Android 4.2.2
Originally posted by Varming View PostThanks for the ROMs. On my old box the 1.2.4 doesn't work with passthrough in JustXBMC
Originally posted by tol View Postk-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
rom 1.0.4 (kitkat) old revision Wasser
Can RK3188 platform fully replace my HTPC?
Hello everybody esp. wasser,
I borrowed before few weeks one K-R42 device. Speed was ok, but i had problems with few things. Because the device was borrowed, I used it only with stock rom.
Few annoying restriction with the device was:
- XBMC don't switch to 1080/24Hz HDMI output (when 24p movie context played)
- XBMC 5.1 AC3/DTS HDMI or SPDIF pass-through don't worked with my ONKYO receiver
(only stereo, receiver was sometimes confused)
- XBMC didn't play my camcorder videos AVCHD 1080i (Panasonic HC-SD60).
(MX-player or BS-player with artefacts)
Please are those problems on RK3188 platform with wasser-firmware solved (esp. 24Hz and pass-through)?
Thank You and sorry for my funny english
firmware-wasser-1.2.4
Hi all.
firmware-wasser-1.2.4 is uploaded. It should support all known K-R42 boards, Please select the correct kernel included in zip file by flashing.
enjoy!
http://www.freak-tab.de/wasser/firmw...sser-1.2.4.zip
Originally posted by cogo View PostThanks wasser for updates. I just installe the newest version. But I do not understand what shoul i do with these kernels?? Which one should I use and how??? I will give you my feedback soon.
thank you wasser for your great work to give the rk3188 more usability!
enjoy!
Hi, is it the same as the one you uploaded on christmas ? ( I see this is not the same link, I'll try it to see).
There is still the cpu limited to 1.4Ghz on new revision ?
Franck.for windows8.1 drivers fix follow this.
Jesurun v2.1 old rev with wasser firmware 1.2.5
K-R42 v2.1 new rev with wasser firmware 1.2.5
Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
Minix neo s8s with stock firmware
Plex streamer with external MX player
TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
Originally posted by franckleroy View PostHi, is it the same as the one you uploaded on christmas ? ( I see this is not the same link, I'll try it to see).
Franck.
Originally posted by MikelThief View PostThis archieve contains kernels for new and old revision and for k-r42 and t-r42 (and unknown for me u1)
Why cant I mount system.img with ImDisk virtual disk in windows ? It says that the volume is not formated. Wasser do you use specific system file ?
It works with HFW system.img.
I'd like to add my remote keyboard layout...
Hi
this new version works pretty well.
But:
+ cpu still limited to 1.4Ghz on new rev board
+ where is the auto hide system bar feature ? disappeared !
+ cant install speedtest.net market says device is not compatible.
+ video playback is not totally smouth on heavy 1080p movies
There are currently 9700 users online. 1 members and 9699 guests.
