K-R42 - wasser firmware - JB Android 4.2.2
Originally posted by pomdeejai View Post
The best firmware for this board is k-r42-old_revision-wasser-1.2.3 with kernel-k_r42_old_revision_cpu1800h_ddr800_1080p_gpu600h.
I have never seen any FW for this device faster than 20859 AnTuTu for 1080p.
Try your link, compare and share your results.CS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
1.) better than "kernel-k_r42_old_revision_cpu1920h_ddr800_1080p_gpu600h.i mg"?
2.) I don't want to diss you, but was the " kernel-k_r42_old_revision_cpu1800h_ddr800_1080p_gpu600h.i mg" with PSU 2 Amp stable, or why do you try another PSU and took unfortunately the wrong Voltage? (I have an 3 Amp PSU from a D-LINK router..)RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View Post1.) better than "kernel-k_r42_old_revision_cpu1920h_ddr800_1080p_gpu600h.i mg"?
2) Was stable absolutely but with good 5V/4A PSU.
I frashed this beautiful board accidentaly with 12V PSU from my Keenetic router, who had the same shape as my 5V/4ACS918II/16GB(HTC-031-V1.0 board)
Originally posted by gotpaste View PostI have 3 k-r42 old revisions with 1.2.4 installed. All 3 devices have the same mac address on the local lan adapter...how do I change the mac address or is this something that has to be fixed in the firmware. Everything else works great.
RK3288 Devices
k-r42 Mac Address
Originally posted by no_spam_for_me View Posthttp://www.freaktab.com/showthread.php?7369-Same-device-other-name-(AC8350-BX09)&p=108521&viewfull=1#post108521
But you wrote:
Originally posted by gotpaste View PostAll 3 devices have the same mac address on the local lan adapter...how do I change the mac address or is this something that has to be fixed in the firmware. Everything else works great.RK3288 Devices
Originally posted by gotpaste View PostThis did not seem to work unless I did it wrong. This is also for the Ethernet adapter instead of the WIFI.
This application can change mac address of your wireless adapter
************** REQUIRES ROOT *************
Features
1. Manage multiple mac addresses/profiles.
2. Turn off mac changing.
3. Changes mac address when wireless turned on by the android.#mac address changerRK3288 Devices
MAC Address
Originally posted by no_spam_for_me View PostBut you wrote:
Originally posted by gotpaste View PostI see in 1.2.4 it says user can change mac address in the notes but does not explain how to do so. I followed the directions above but that appeared to be for the WIFI adapter and not the LAN adapter. It also didn't seem to work for the WIFI. I really like this rom as everything is very smooth and seems to work great with latest xbmc nightly. Any help would be greatly appreciated. Looking for a permanent solution as I have seen some things about spoofing the MAC but that looks like it only happens until the device is rebooted. If there is another kernel I need to flash please let me know where to locate. Thanks Again
"... which allows constant Ethernet MAC address ..." (frist link)
or
" ... Second method require creation of file containing LAN MAC adress: /data/misc/wifi/wlan_mac ..." (second link; including explanation why you don't get different or constant mac-addresses at LAN
(the kernel read the file /data/misc/wifi/wlan_mac)
and yes because of this it didn't work for WIFI (but don't ask me wy the calling is "wlan_mac" at folder "wifi")
What I don't really know, but I don't think so, perhaps wasser has it removed form newer release...RK3288 Devices
MAC Address
Originally posted by wasser View Postfirmware-1.2.3 supports static ethernet mac adress. for static mac adress you should add it in /etc/ethernet-mac
Originally posted by gotpaste View PostI may not have been specific enough. I have 3 K-r42's old revision. Recently I installed Wasser 1.2.4 1080p boot and kernel on the device. I have them hooked up via hardwire to the Ethernet port. All 3 devices show the same MAC address so they are all conflicting with each other on the network. I see in 1.2.4 it says user can change mac address in the notes but does not explain how to do so. I followed the directions above but that appeared to be for the WIFI adapter and not the LAN adapter. It also didn't seem to work for the WIFI. I really like this rom as everything is very smooth and seems to work great with latest xbmc nightly. Any help would be greatly appreciated. Looking for a permanent solution as I have seen some things about spoofing the MAC but that looks like it only happens until the device is rebooted. If there is another kernel I need to flash please let me know where to locate. Thanks Again
There are currently 1685 users online. 0 members and 1685 guests.
