K-R42 - wasser firmware - JB Android 4.2.2
K-R42 firmware by wasser
iamsamsamiam
Thanks for your advice. Unfortunately, I have restored the stock firmware, because yesterday nothing could be done with this trouble.
How not to change a files used in the firmware on the files from the other firmwares - to no avail.
Not tried only kernels of firmwares Lewy, because its firmware older than version 1.2 on my device does not work. But on firmware 1.2, which works great, better than anyone I've tested, there is no LAN-connection, for this reason and kernel this firmware did not try to install.
I will try to use your advice next time.
WINDOWS 7 FIRMWARE DEVICE DRIVERS FOR T-R42
Hi ALL
Looking for device drivers for wasser 1.2.4 firmware... After flashing the box i want to connect to my pc to run adb tools.. cannot load any of the samsung device drivers for the GTI9300 which is spoofed in this firmware...
windows wont accept any of the device drivers i have associated with samsung.
firmware runs smooth... the best i have used so far with the T-R42.
I have load the firmware with apps... done a rom backup using CWM RECOVERY and ROM MANAGER having a few issues try to load on another identical box using rom manger to load... it wont see the backup when installing from the SD CARD.
Any suggestions would be appreciated.
Thanks in advance
"After flashing the box i want to connect to my pc to run adb tools.."
You need the rockchip-drivers... have a look at my sig at dump...
#2 and #3 (moborobo)RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View Post"After flashing the box i want to connect to my pc to run adb tools.."
If "I can flash the box fine no problems.." the "classdriver", witch is needing in recovery-mode, works fine...
For ADB in normal-mode you need another driver. The "Android Composite ADB Interface..." driver, witch you can install for example by moborobo http://www.freaktab.com/showthread.p...l=1#post106326 AND you must configure your android like this
Settings -> [DEVICE] USB -> Enable Connect to PC
Settings -> [PERSONAL] Security -> Enable Unknown Sources
Settings -> [SYSTEM] Developer options -> Enable USB debuggingRK3288 Devices
Originally posted by no_spam_for_me View PostIf "I can flash the box fine no problems.." the "classdriver", witch is needing in recovery-mode, works fine...
Thanks for your reply my friend .....tried all that ADB still does not work ... ADB INTERFACE driver is loaded but none of my ADB TOOLS can't see the device! surley the GTI9300 driver is out their for it
Perhaps I don't really understand your problem... The device is a rk device, but in the android the device it is perhaps called GTI9300 because of compatibility at the google play store, so the most apps (specially handy-apps) are able to install...
I use an older version of wasser mod, but if I connect the device in "normal mode" at my pc, I only see it at the device manager (Win XP) as:
- Android Phone
-- Android Composite ADB Interface
Nothing with GTI9300 or so on...RK3288 Devices
Originally posted by no_spam_for_me View PostPerhaps I don't really understand your problem... The device is a rk device, but in the android the device it is perhaps called GTI9300 because of compatibility at the google play store, so the most apps (specially handy-apps) are able to install...
- Android Phone
Thanks for your Help
I'm not sure, but perhaps you have to start the ADB with administrator privileges (I'm actually not at my PC)?
The neomode version of ADB works for me (another one not)...RK3288 Devices
ADB
Hello bigbow64,
I had the Same issue so I loaded Moborobo ... it has its own ADB drivers ...
Start it and connect to the player. Then Leave it running and then start adb in a command window
this works for Me ... List will then show the Media Player ...
NOTE YOU MUST LEAVE Moborobo Running... for this to work
Good Luck
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
There are currently 9703 users online. 1 members and 9702 guests.
