K-R42 - wasser firmware - JB Android 4.2.2
Originally posted by euklid81 View PostI just got the k-r42..I want to try this firmware..question is how do I know which revision of the device I have??
Try the old version and if wifi or lan doesn't work then flash the new one.
I went thru this last night with my sisters machine and couldn't work out why both of them were failing on wifi. Eventually I tried the T-R42 firmware instead and that worked. They had sent her a T-R42 with bluetooth instead even tho I had ordered the K-R42.To Infinity and Beyond.... XBMC
K-R42 firmware by wasser
I still can't get the latest two versions on my box 12.2 or 1.2.3 . Both appear to flash perfectly however I get a black screen with no output via hdmi or composite.
The rom does not come with a flashing tool however I use the 1.7 that came with another rom. Is this okay.
I am sure I am doing everything okay since other Roms I flash work fine.
My tv is a modern samsung 1080p 47 incher so I'm sure that isn't the problem.
Has anyone ever had any weird experiences like mine? I've downloaded it several times both versions and it. Doesn't work. However the slightly harder flashing process of 1.2.1 which uses the different flashing method when you have to select the various parts to flash works fine.
Please help. I'm desperate to get a stable netflix box up and running.
Sent from my iPad using Tapatalk HD
How to tell revision?
Hey all - not actually sure which model I actually have, was bought off **** as a generic Android device with nothing on the box in terms of model number. It is RK3188, based off settings > about (looks identical to pictures are any of your devices), and I also managed root using instructions here.
Question is how do I tell what revision I have, and any idea if I can clarify which model I have (from the board perhaps - I haven't yet opened)?
*** OK - just searched thread and saw that flashing either should be fine to see which one works.
hey wasser,
i just receive a new box and i open it to see what version i got .
b351 v1.1 1338 ...sound new if its 1338.
the box boot on new and old revision but on new it crash in setting when switching wlan or lan ...wont turn toggle on.
on old revision there no crashes but wlan wont turn on and lan turn on and off but does not connect
any suggestion? please help
**edit i think, better yet im sure the seller sent me t-r42 instead .
question: is it same as the k-r42 just with bluetooth or should i return it
I also have K-R42 from geekbying. PCB is B351 V2 (date 2013/09/22). I can't get any of Wasser fimrwares to work properly. Best result I got with "k-r42-new_revision-wasser-1.2.2". But even that does not work better than stock firmware. There were problems with wifi, and could bot get NAND to work. Could be that I'm doing something wrong.
At the moment I'm using this (http://pan.baidu.com/s/1f7pYV). If I can help testing something, please let me know. Keep up the good work!
Originally posted by Jb0nd View PostI also have K-R42 from geekbying. PCB is B351 V2 (date 2013/09/22). I can't get any of Wasser fimrwares to work properly. Best result I got with "k-r42-new_revision-wasser-1.2.2". But even that does not work better than stock firmware. There were problems with wifi, and could bot get NAND to work. Could be that I'm doing something wrong.
should work...work for me
Question on justXBMC apk file
the xbmc app crashes randomly, is there a newer version available because everything runs smooth on this firmware
or can i just update it with a normal xbmc now after installing this justxbmc app ?Home Cinema Setup Livingroom:
50" Panasonic Plasma - CS-X806 (s802 1gb/8gb) with Mele F10 on OpenElec 5.0.3 with Kodi - Pioneer Receiver - JBL Surround System - 4TB NAS
Bedroom Media Setup:
32" Philips LCD - KR-42 wasser rom
Originally posted by QuAn64m View Posthey wasser,
i want to use the hybrid rom 2.0.4 by lewy and your oc kernel. but after i flashed your kernel the density is changed. everything is so small =) can you help me ?
thank you
Run ES File Explorer (or any other file manager with root).
Enable allow it to run with root features.
Navigate to /system
open up build.prop as a text file
Scroll down to the "ADDITIONAL_BUILD_PROPERTIES" section
Find "ro.sf.lcd_density="
Change the number after the "=" symbol to something higher than what it is (if you don't know I suggest you start with 200 to see what you like)
Restart device
I can't help directly, but others may be able to assist further/quicker if you link to the Amazon page for the product you purchased - someone else may have bought it as well, or recognize some of the sales blurb.
Originally posted by gedas3 View PostHi. Bought cs918 on Amazon. Trying every firmware can find. The device is not booting, stuck on boot logo.
(CUT FOR BREVITY)
Sent from my HTC One using Tapatalk
There are currently 2942 users online. 3 members and 2939 guests.
