K-R42 - wasser firmware - JB Android 4.2.2
Originally posted by curlyboi View Postwill i have to reinstall the whole firmware or will just kernel be fine?
Originally posted by wasser View Postyou only need to flash new kernelanyway, i was trying to do the static mac fix, so i added a file 01mac.sh into /system/etc/init.d, with LF line endings, 755 chmod and this content:
Code:#!/bin/sh ifconfig eth0 hw ether 00:91:30:80:20:17
I got old k-r42 - all is ok on last wasser`s firmware , but tv out is strange:
If I turn on box with tv out its starting ok, but resolution is 1080p and I see only left up corner of my launcher. So after booting in launcher I have to plug hdmi in then out and after that I receive normal screen in tv out mode.Last edited by Hotabych; 23 November 2013, 08:43.CS918(old wifi)+Air Mouse ea-01
Out: TV LG HDMI (1 day a week AV out Samsung Tv)
CX919(wifi ap6210)+Mele F10
Out: TV LG HDMI
Originally posted by Hotabych View PostI got old k-r42 - all is ok on last wasser`s firmware , but tv out is strange:
I'm using the firmware 1.2.2 old revision on my k-r42.
I can enable wifi or ethernet.
1) In wifi or ethernet I can't open Google Play store:
The first time I launch it it asks me for my login/pwd. And then it closes itself
I tried also with a new fresh google account, same behavior.
2) I downloaded speedtest.apk from another source than play store and installed it:
Ping test works
download test works
upload doesn't start at all
3) ifconfig after speedtest in wifi
lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
p2p0 Link encap:Ethernet HWaddr 02:77:0E:01:4D:98
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:849 overruns:0 frame:0
collisions:0 txqueuelen:1000
wlan0 Link encap:Ethernet HWaddr 00:77:0E:01:4D:98
inet addr:10.0.0.2 Bcast:10.0.0.255 Mask:255.255.255.0
inet6 addr: fe80::277:eff:fe01:4d98/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:12231 errors:0 dropped:98 overruns:0 frame:0
TX packets:6740 errors:0 dropped:1 overruns:0 carrier:0
RX bytes:17189102 (16.3 MiB) TX bytes:705682 (689.1 KiB)
eth0 Link encap:Ethernet HWaddr 12:AE:4D:57:88:97 inet addr:10.0.0.5 Bcast:10.0.0.255 Mask:255.255.255.0
inet6 addr: fe80::10ae:4dff:fe57:8897/64 Scope:Link
RX packets:16388 errors:4089685339 dropped:4089606664 overruns:802485 frame:4088882854
TX packets:7108 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:16764746 (15.9 MiB) TX bytes:709395 (692.7 KiB)
Interrupt:51 Base address:0x8000
Originally posted by curlyboi View Postthats good newsanyway, i was trying to do the static mac fix, so i added a file 01mac.sh into /system/etc/init.d, with LF line endings, 755 chmod and this content:
Code:echo "00:91:30:80:20:17" > /data/misc/wifi/wlan_mac
Code:#!/system/bin/sh
RK3288 Devices
- Overview BOX (LINK !)
I just found what causing those strange bug with Google Play store and Speedtest.
I just modify my MTU to 1460 on eth0, and now speedtest uploads correctly and even playstore launch correctly.
So I suppose my router didn't like MTU 1500.
EDIT: I did the same modification on the wlan0, and it also works.
But I don't know howto make this modifications on MTU permanent.
Originally posted by no_spam_for_me View PostHi,
not to apologize
OK I try it with cwm
1. wipe data/factory reset
Code:-- Wiping data... Formatting /data... Formatting /cache... Formatting /sd-ext... No app2sd partion found. Skipping format of /sd-ext. Error mounting /sdcard/.android_secure! Skipping format... Data wipe complete
Code:-- Wiping cache.... Formatting /cache... Cache wipe complete.
Code:Dalvik Cache wiped.
settings -> storage -> <Mount Nand Flash>?
I didn't get any symbol in the right screen corner?
The only think is, I've lost all my installed application (no matter I've a script to install them via adb BUT now I've the device as "Nexus 7" in my windos explorer...(OK "Connect to PC" AND "USB debugging"))
The fix is really easy
because it didn't work for me ....
Some other idea?
RK3288 Devices
There are currently 1893 users online. 0 members and 1893 guests.
