K-R42 - wasser firmware - JB Android 4.2.2
Originally posted by darkneo29 View PostCS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
Originally posted by darkneo29 View PostThanks, so if i flash the wrong version what type of issues should i have? Also is 2.1 the newest?
In case you flash wrong FW version, you won't have LAN in working condition only.CS918II/16GB(HTC-031-V1.0 board)
Originally posted by franckleroy View PostHi wasser
overclocked kernel are worst on my device, only 1200Mhz clock availaible !
One idea ?
Franck.
It is quite strange.
Which of your device and what kernel you are speaking about.
I had tried to flash kernel-k_r42_old_revision_cpu1800h_ddr800_1080p_gpu600h on my device which is in my sigh bellow and was showed with 1200-1800 frequency interval. I use v4.0.4 for tests.CS918II/16GB(HTC-031-V1.0 board)
oc kernel cpu clock problem with new rev FW
Hi
I did not try oc kernel on old rev (May be I'll be it tonite)
On new rev, cpu clock is 1400Mhz and using a oc kernek it is min&max set to 1200.
I try with many "set cpu" tools, all tools say the same; min&max=1200.
I also try a oc kernel from minix (something like cpu 1800 gpu 600 ddr 720). Kernel works pretty well ;') but no lan no wifi. On such kernel max cpu is only 1600 (no 1700 no 1800 as it could be expected).
I check files in /sys/blah blah/cpu/blah-blah, and min&max are '1200000', tried to change file contents but this is useless....
I'll try tonite with my old jesurun that runs with old rev (by default this is cpu 1600).
Franckfor windows8.1 drivers fix follow this.
Jesurun v2.1 old rev with wasser firmware 1.2.5
K-R42 v2.1 new rev with wasser firmware 1.2.5
Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
Minix neo s8s with stock firmware
Plex streamer with external MX player
TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
Fantastic !!!!!
Wasser Hello, I am very satisfied with your new ROM. I'm using the new revision 1.2.3 on my CS-918 device. It was not necessary to use any additional OC, do I run JB 4.2.2 system using the CPU in the range 1200-1600 MHz without problems some MKV files in high definition. I thought the ROM super fast and without lags. My broadband reaches at 30 MB and can browse the internet with enough fluidity. Loved the initial boot and applications that you installed, especially the native system reading of NTFS, NFS, ISO, etc .... Congratulations for the good work, I can honestly say that this ROM is the best I have ever experienced. For now it's just, I will do more testing and get back to you to communicate the results.
Hugs coming from Brazil for you.
Even more!
K-R42 firmware by wasser
People, you should stay on 1.4 GHz frequency because on higher freqs you are slowly damaging your device because power converter in KR42 is not suited to work kind under heavy tasking at higher freqs than 1.4GHz
Wysłane z mojego iPhone 5 przez Tapatalk Professional
Originally posted by franckleroy View PostHello I use :it.sineo.android.noFrillsCPU to control CPU and max is 1.4 with new-rev (1.6 with old-rev).
I'll try SetCPU for root users tonite.
Franck.
But no matter the oc kernel used, cant have smooth playing on amazing spiderman (1080p with dts 1500k).
Originally posted by MikelThief View PostPeople, you should stay on 1.4 GHz frequency because on higher freqs you are slowly damaging your device because power converter in KR42 is not suited to work kind under heavy tasking at higher freqs than 1.4GHz
My mesurement with kernel-k_r42_old_revision_cpu1800h_ddr800_1080p_gpu600h showed me max. 1,75A while runing AnTuTu test. 5V 4A PS was used for test. Any other device besides USB wired mouse was connected to device during the test.
So if you want to use high speed kernel with appropriate stability level I would recommend you to change your PS for more powerful one(min 3A). And if you want to connect your unpowered USB HDD (like mine WD My Passport 500GB) to the box, it is necessary to use additional powered HUB too.
I'm not shure we'll spoil our device with stock 2A PS(fake 2A, real up to 1.6), but we'll have parmanent reboots or fried PS eventuallyCS918II/16GB(HTC-031-V1.0 board)
Originally posted by franckleroy View PostJust tried oc kernel on old rev firmware and all expected clocking are availaible.
Franck
I hope your movie isn't VC-1 or MPEG-2, because these are supported by HW/SW mode only but with some size/bitrate limitation unfortunately.CS918II/16GB(HTC-031-V1.0 board)
Please HELP
Hello,
I desperately need your help with the k-r42 that my friend purchased from geekbuying in September. He got it two weeks ago. Please see attached images of the inside of the device.
He wasn't pleased with the performance of the unit so I recommended him to flash wasser's ROM. He flashed both revisions the OLD and the NEW. With both of them the WiFi doesn't work. I feel very bad about it because I recommended him to buy this unit and I recommended him to flash a custom ROM. Now he is really upset and me too.
How can he make it working again. He didn't backup the original FW.
Thank you!
Update: It turned out that he ordered T-r42Last edited by mowgli; 29 November 2013, 04:52.
bad tv out
I am still having problems with TV OUT in 1.2.3
I have a projector and old CRT TV. The projector is VGA so I am using HDMI2VGA adapter from dealextreme, which is working great. The projector is 720p so that's the max resolution the box allows me to set and I am happy with it.
BUT: No matter what I do, I can't get a good picture with the TV OUT. When I start the device, the TV is blank. If I enter system settings, and switch the TV format from PAL to NTSC (and optionally back again to PAL), I get a picture, however, it is very distorted. I think the RGB color layers are offset and floating apart. Also, the picture is only stretched this way in the bottom half of the picture, the top remaining blank.
I tried disconnecting the HDMI, which didn't make any difference. When I connected it back, the TV OUT went blank again and was only enabled again after switching the TV format to NTSC and back to PAL again.
I need both outputs to work simultaneously, e.g. I can watch something on my projector and my gf watch the same thing when she has to do something in the other room with the old TV.
Please help?
Lewy's 2.0.4 worked good with this with some of the newer wasser kernel...
Hi All
I finally got my k-r42 to work with Wasser 1.2.3 New Version
What I did was to unpack with the RKTOOLS 3066 :
Unpack wasser 1.2.3 new ver
Unpack the Chinese : update-rk3188t-bx09-android4.2.2-yigeweiye-20131101
unpack justXBMC 1.1.1
Then in RKBATCH tool 1.37 I set : loader + boot + kernel from Chinese bx09 image
Recovery from justXBMC 1.1.1
And all other (parameter + misc + system )from Wasser 1.2.3.
Erased nand/IDB and flashed rom.
box booted just fine , Nand mounted correctly , lan works , wifi works (even at the same time)
normal boot about 10 seconds, antutu score 17206.
I just needed to go to settings and set resolution to 720p , because screen was not showing all.
then I flashed only wasser 1.2.3 new ver kernel + boot - and box still booted (-: , all working as before.
Antutu score :16104 lower than stock kernel ?, strange .
so I flashed OC kernel : kernel-k_r42_new_revision_cpu1704_ddr720_1080p_gpu600h
antutu score : 16204 .
re-flashed bx09 kernel back and tested again : same result as before 17206.
I am running wasser image with only Chinese loader and justXBMC recovery ,
should the make my box run lower speed with wasser kernel ?
I do not care much about antutu , what kind of improvements do i get with wasser kernel ,
that i do not get with Chinese kernel ?
hope this will help all who have issues with getting wasser/other roms to work .
also maybe will work directly with just to choose Chinese loader + justXBMC recovery , or just one of them , I did not test.
black screen after upgrade
hello,
i'm experiencing some troubles after updating to rom 1.2.3 (tried new & old version)
used the rkbatchtool to select the firmware, upgraded my k-r42, update succesfull but when i connect k-42 to tv I , tv screen remains black ..
connected with hdmi, sound via spdif to bose lifestyle surround system.
i change resolution of tv to 720/1080, both doesn't work ...
also tried the solution vipersvcd proposed in the post before, but always getting error message that loader file is not valid ... perhaps invalid downloaded file (took about 3 hours to download), now trying again ..
i'm not really an expert in this matter, any tips ?
regards
Kris
regards
Kris
When you flash your device using RKbatchTool you mustn't apply "Upgrade" button. "Restore" is correct in this case. And you have to wait for up to 5 min. after RKbatchTool finishes his work. Then you'll see "X" bootanimation screen.CS918II/16GB(HTC-031-V1.0 board)
There are currently 3278 users online. 0 members and 3278 guests.
