K-R42 - wasser firmware - JB Android 4.2.2
OK, first problem, know you use rkbatch (instead of 1.2.1), but it isn't included in the archive
downloading old_revision...
PS: sorry for the double postRK3288 Devices
- Overview BOX (LINK !)
First short test
OLD Revision (my PCB: CH001 1332 TN-BX09_V2.1 2013/05/31)
1.
INTERNAL STORAGE => 1.97GB
NAND FLASH => 4.29GB
(BTW: what's about the missing ~1.7GB? I think ~350MB is Backup-mnt, but where is the rest?)
2.
LAN => ok
WLAN => ok
3.
justXBMC crashes at first start, next start is ok
4.
Screen resolution => 720 (672 because of the "footer" menu)
(with justXBMC/System/"System Info", http://www.whatismyscreenresolution.com/ and Android System Info 1.25.2)
setting is 1080P@50Hz
?????????????????????RK3288 Devices
Version 1.2.3 old revision
Everything works great:
wifi
ethernet
passthrough spdif
I watched this afernoon avatar in 720p, sounds and image was great, but justxbmc stopped playing my video after a 2min pause and resuming.
I still need to change my MTU on wlan0 or eth0 to be able to use Google play stor, upload on speedtest or even to download addons/skins.
But even MTU changed to 1460, skins downloading is really slow(it was the same with 1.2.2).
My router is connecting to my VDSL provider in PPPOE with MTU 1492. Not sure it's related.
Speedtest gives me 30Mb/s in download and 3Mb/s for upload
EDIT:
I have a lot of dropped RX packets on my wlan0:
RXPACKETS: 2903685 errors:0 dropped:21123 overruns:0 frame:0
wifi
ethernet
passthrough spdif
On 1.2.1 only DTS was working. On DD5.1/AC3 the amplituner gets DD stream but there was silence in speakers.
I'm still waiting for DD5.1 passthrough via SPDIF. Does anyone know is this possible?
Originally posted by hoborg View PostHave you tested passthrough spdif for DD5.1/AC3?
Originally posted by heyyo View PostYes AC3 works correctly via SPDIF. To make it work don't forget to select SPDIF output in Android settings and in XBMC.
Then I installed justXBMCv4.apk from Lewy. The error gone and I saw "libmedia hack ... " at "passthrough output devices", but still nothing. Playing video wasn't smooth and there was no sound even though receiver signals that he gets an DD stream.
I'm loosing hope.
It seems so, perhaps that the /system/lib/libmedia.so have to fitt to the justXBMC.apk
At the moment in 1.2.3 justXBMCv3.apk is installed, but I don't know, how and from where you get a fitting /system/lib/libmedia.so, so you can try justXBMCv4.apk...
BUT only think so, don't really know it (ask at lewy20041 thread but get no answer)
PS: downgrade to 1.2.1 because of 1080P...Last edited by no_spam_for_me; 24 November 2013, 01:40.RK3288 Devices
external sound card
gentleman, would anyone happen to know how to handle MULTICHANNEL sound with external USB sound card?
i have a 5.1 setup but it doesn't have SPDIF input (its just a cheap Genius setup although all-wooden and good sound which i got for about $110). in my computer, i used external soundcard SoundBlaster X-Fi Surround 5.1, which then feeded all six cinches on the speaker input unit.
when i connect this sound card to my jesurun dx05, i see it in the sound manager. so i select it. but the sound comes out only as stereo and i get awfully lot of crackling. i have a dolby multichannel test video which testes all audio channels and shows on the screen which of them are playing. FrontLeft goes to FL speaker, Center goes to FL and FR speaker, FR goes to FR speaker, RR goes to FR speaker, RL goes to FL speaker and the subwoofer is silence at all.
i tried to play this video in both xbmc and internal rockplayer, both of them no good (in the internal player, the picture was also in wrong aspect ratio, but nevermind that, im using xbmc to play my videos)
please help?
Originally posted by no_spam_for_me View PostIt seems so, perhaps that the /system/lib/libmedia.so have to fitt to the justXBMC.apk
In the xbmc settings you have to ignore the "Passthrough output device" - "No devices found" as this comes up because passthrough with a RK3188 is an unofficial hack. The reason it does not come up in justXBMCv4 is because the code was changed to hide it.
Its strange that you are having issues with spdif passthrough as hdmi passthrough works with everything. You could copy the libmedia.so file from justXBMC Rom using ES Explorer to USB and copy that to wasser rom and see if that fixes it.
BTW: libmedia.so's are different in 1.2.1 and 1.2.3 (binary compare with "Beyond Compare 3")RK3288 Devices
There are currently 2434 users online. 1 members and 2433 guests.
