K-R42 - wasser firmware - JB Android 4.2.2
    Hi wasser,
    I'm in process of regular testing of your FW (revision is specified below). I had done my tests a bit longer and noticed that I'm not able to watch any movie via LAN entirely from the beginning to the end. Box is always rebooting or switching off at all after various time which is about one hour or less.
    I suppose these errors which ifconfig log shows to us and the situation when you couldn't find Eth switched on in my dmesg log( but it is switched on in fact), say about some kind of existing conflict in system.
    Have you been visited yet by any idea how we can solve this issue?
    If you want me to do any special test, just let me know.
    And one more question for you. Can you give me advice how to switch 1080p mode so that the system wouldn't change resolution automatically and would allow me to have screenshot function working properly?
    Sorry if I load you so much.
    CS918II/16GB(HTC-031-V1.0 board)
    CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
    K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
      Hi guys,
      It looks like the secret of difference among the boards for NON BT devices TN-BX09_V2.1 from 2013/05/31 has just been discovered!
      It is fresh news from our Russian speaking community 4PDA where man DEPECHE has found the main difference in number 1332 and 1335 which is printed on board too. It is suspected these numbers mean the week of born. So 32 is older than 35. Therefore, 32 corresponds to OLD version of wasser's FW, while 35 corresponds to NEW one.
        Originally posted by digger View Post
        Hi guys,
        Hi Wassar/digger and all of you guys,
        I got my k-r42 only a couple of days ago from geekbuying. I opened the case and, as you can see, it's also a v2.1 dated 2013/05/31, but instead of 1332 or 1335, it is numbered 1340.
        Did any of you bumped into this printed number?
        Is it safe to install Wassar's FW on it?
        I'll be happy to be advised,
        regards!
          I don't really know it, but how I understood it, it means >=1335 is new revision... BUT I only think so...
          RK3288 Devices
          - Overview BOX (LINK !)
            I just saw now that lefizz got the same board: link
            He wrote that it works fine, too: link.
            Here I go...
              Originally posted by wasser View Post
              - your /mnt/xyz is created on boot partion which is always reset to default by reboot. it means you lost
              your /mnt/xyz. You should create your xyz in /sdcard or fix your boot image
              I've fixed it with my really first init.d script I ever done...
              Code:
              [FONT=courier new]#!/system/bin/sh
              # * NFS mount *
              # copy to /system/etc/init.d
              # change permisions to "755" "rwx r-x r-x"
              # reboot
              # using this in -> cmd-install-NFS.cmd <- for installation (without #)
              # adb remount -oremount,rw /
              # adb push [I]<script-name>[/I] /system/etc/init.d
              # adb shell chmod 0755 /system/etc/init.d/[I]<script-name>[/I]
              # adb remount -oremount,ro /
              # adb shell ls -al /system/etc/init.d/
              # adb reboot
              # pause
              while [ ""`getprop dev.bootcomplete` != "1" ] ; do sleep 1; done
              mount -o rw,remount /
              mkdir /mnt/[I]<folder-name>[/I]
              mount -o ro,remount /
              sleep 2
              busybox mount -t nfs [I]<NFS-IP>[/I]:/[I]<share-name>[/I] /mnt/<folder-name> -o ro,intr,soft,udp,nolock,rsize=8192,wsize=8192
              # done[/FONT]
              RK3288 Devices
                Hi tol,
                I absolutely agree with no_spam_for_me, you have newer revision. And if I were you I would try to flash it with k-r42-new_revision-wasser-1.2.2 firmware.
                  I'm still using wasser's new revision 1.2.2. I was curious and opened up my box. I also have the 1340 number. All is well with it, but i do have 3 problems/questions
                  1. when i power down with remote and power up later in the day (with remote), my screen will turn black and i have to unplug the power cord on the box to reboot correctly. Any help would be appreciated.
                  2. (not as a big deal) when i use the reboot app (in the app section), everytime it starts up I no longer have lan. Only cure is to unplug power then plug back in. This isn't a big deal, just noticed it while testing the power functions above.
                  3. I want to add the 360 controller files that i must change permissions for. Can I ftp using justxbmc, if so, what is the username and pass?
                  Thanks to all
                    Hi tol,
                    Hi digger and no_spam_for_me,
                    Thank you both - I just flashed the new 1.2.2 Wasser's FW.
                    It seems to work fine. I'll have a more thorough test later on.
                    regards!
                      Wasser, I see you thank minix for the firmware in your first post.
                      Is 1.2.2 based off the minix 007 firmware with the newer kernel ?
                      To Infinity and Beyond.... XBMC
                        Hi guys,
                        I'm not 100% convinced as I installed the "old" version, everything works fine (Lan and Wifi).... then i opened my K-R42 out of interest and its marked 1335
                          It sounds kind of strange. Did you applay EraseIDB before flashing k-r42-old_revision-wasser-1.2.2? Whose NAND is soldered on your 1335 board in, SKhunix or Toshiba?
                            I have 1325 board the very oldest
                            k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
                            rom 1.0.4 (kitkat) old revision Wasser
                              Originally posted by dzidek View Post
                              You must turn it on manualy, after that system will ask You to format new storage!
                              I did it in that way and it works
                              How do you force it?
                              I also have the problem!
                              ES File explorer: "SDcard unmounted"
                              Android System Info: "SDCard Max 0.0MB Free 0.0MB"
                              MX Player Pro: "SD card is not recorgnizable"
                              RK3288 Devices
                                hey no spam
                                I had those issues. Not sure if this is definitely the order i did things but this works for me.
                                go to settings then storage
                                choose mount nand (nothing really happens)
                                i eventually saw an icon on the bottom left next to the time and clicked on it.
                                asked if i wanted to format storage which you do want
                                That did it for me
                                btw, i figured out the black screen problem after i turn on with the remote. I was powering off while having justxbmc open then trying to power on later. When I power down at the android screen it opens correctly.
