K-R42 - wasser firmware - JB Android 4.2.2
    Is it possible to write different kernel modules for different ir drivers that are flashable separately? Would be cool to have the option to change ir remote driver inside android settings. Any chance for that option?
    Donations are welcome and will be shared with other devs:
    DONATIONS
    CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
      Originally posted by wasser View Post
      it's fixed in 1.2.5 firmware.
      thank you very much for your hard work
      much apreciated !
      Home Cinema Setup Livingroom:
      50" Panasonic Plasma - CS-X806 (s802 1gb/8gb) with Mele F10 on OpenElec 5.0.3 with Kodi - Pioneer Receiver - JBL Surround System - 4TB NAS
      Bedroom Media Setup:
      32" Philips LCD -
      KR-42 wasser rom
        Bluetooth Wasser 1.2.5
        Hi
        I have wasser 1.2.5 (awesome software) and a couple of bluetooth dongles I'm hoping to use. What kernel can I use to get the bluetooth working as I really want to hook up my gamepads. Hope someone can help (I'm running the kernel-k_r42_new_revision_cpu1920h_ddr720_1080p_gpu600h and it's fantastic)
          Man i just tried this 1.2.5 rom with the kernel-k_r42_old_revision_cpu1800h_ddr800_1080p_gpu600h kernel....
          runs so damn smooth, never ran like this before....
          Awesome wasser !
          i made a donation to ya for your hard work wasser !
          32" Philips LCD -
          KR-42 wasser rom
            Originally posted by alimickwhit View Post
            Hi
            extern bluetooth dongle isn't supported yet in the firmware.
            wasser
              Awesome wasser !
              LeXXoZ, thanks for your donation!
              I'm very glad to hear that you like my rom
              wasser
                Walter, it's possible but requires a lot of work. I remember you sent me some infos last time. Sadly it's lost. Could you please send me the infos again?
                thanks
                wasser,
                  External Bluetooth
                  wasser
                  Thanks for letting me know, I guess the T-r42 1.2.5 does support the internal bluetooth. Is that right?
                  P.S awesome work. XBMC Gotham beta so nearly makes the r42's some of the best droid boxes. I run TVHeadend and everything works fine except UK HD sat in h264
                    Sorry is good this firmware for CS918 ?
                      yes, only internal bluetooth is supported in t-r42.
                      wasser
                        noticed that my logitech camera isnt working anymore ?
                        just a driver to load externaly ?
                        32" Philips LCD -
                        KR-42 wasser rom
                          LeXXoZ, which logitech camera is it?
                          i have the Logitech C160 USB Webcam, it works for me.
                          wasser
                            thanks
                            wasser,
                            Hey Wasser, here back at home on 24.03. but here are the infos i have:
                            Debug Kernel 1:
                            u=0xff
                            Debug Kernel 2:
                            PowerButton d=18e7
                            1 - d=2ad5
                            2 - d=12ed
                            3 - d=e01f
                            4 - d=af5
                            5 - d=48b7
                            6 - d=8877
                            7 - d=32cd
                            8 - d=708f
                            9 - d=b04f
                            0 - d=30cf
                            SPACE - d=827d
                            DEL - d=d22d
                            HOME - d=609f
                            BACK - d=2fd
                            MENU - d=20df
                            234 (Aktivate Mouse) - d=e817
                            ENTER - d=aa5
                            DPAD_LEFT - d=e21d
                            DPAD_UP - d=629d
                            DPAD_RIGHT - d=a857
                            DPAD_DOWN - d=6897
                            VOLUME_DOWN - d=28d7
                            VOLUME_MUTE - d=10ef
                            VOLUME_UP - d=8f7
                            RED Funktion Button - d=6a95
                            Green Funktion Button - d=ea15
                            Yellow Funktion Button - d=b807
                            Blue Funktion Button - d=da25
                            Stock kl Keymap:
                            key 28 ENTER
                            key 116 POWER WAKE
                            key 158 BACK
                            key 139 MENU
                            key 217 SEARCH
                            key 232 DPAD_CENTER
                            key 108 DPAD_DOWN
                            key 103 DPAD_UP
                            key 102 HOME
                            key 105 DPAD_LEFT
                            key 106 DPAD_RIGHT
                            key 115 VOLUME_UP
                            key 114 VOLUME_DOWN
                            key 143 NOTIFICATION WAKE
                            key 113 VOLUME_MUTE
                            key 111 DEL
                            key 14 VOLUME_MUTE
                            key 2 1
                            key 3 2
                            key 4 3
                            key 5 4
                            key 6 5
                            key 7 6
                            key 8 7
                            key 9 8
                            key 10 9
                            key 11 0
                            key 521 TV_KEYMOUSE_MODE_SWITCH
                            key 522 SPACE
                            key 523 POUND
                            This is for CX-921 first revision without bt.
                            I just had the idea to have a kernel to boot nearly all rk3188 devices with the option to install specific kernel modules for a lot of devices, like ethernet, wlan, bt, or ir driver.
                            Keep on your great work!!
                            All the best
                            walter77
                            Gesendet von meinem iPad mit Tapatalk HD
                            DONATIONS
                              overclock to 1.8g
                              Hi, I am using 1.2.5. Everything is good.
                              Can I overclock to 1.8g with 1.2.5 kernel?
                              How to do it?
                              thanks.
                                Hi wasser,
                                Excuse me, please, for my insistence with my question to you asked third time.
                                Do you expect any improvement with increasing of GPU performance, which is still limited at 446 for "T" based chip?
                                CS918II/16GB(HTC-031-V1.0 board)
                                CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
                                K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
