Hi does anyone know if i got the above box and its firmware are other people getting a random standby mode on these boxes as mine seems to go into standby every so often half way through a film
K-R42 - wasser firmware - JB Android 4.2.2
Originally posted by LeXXoZ View PostAny news on a new firmware ?
would like to use my camera again
Please download it and copy to /system/lib/hw/
Please don't forget to check the permission of this file, it should be readable for all
the permission should be look: -rw-r--r--
reboot device, usb webcam should work.
download url: http://www.freak-tab.de/wasser/camera.rk30board.so
Originally posted by wasser View Posti uploaded new camera.rk30board.so which should fix the issue in usb camera.
However, the sound I get for video (tested with hangouts) is the same as a smurf. I've tried changing the sound output but nothing changes. It's actually very funny, but we can not have a normal conversation if we're laughing all the time.
Sincerely thank you again for your work.
Edit: I tried later with Skipe and works perfectly, both the video and sound. Then the optimization problem seems to be the hangouts. Thank you again and I sent a small donation for your work.Last edited by alexge; 27 May 2014, 19:59.
Having some strange behavior lately
i have mounted my nas with a script by init.d when i start a tv serie and open it with MX Player or default player the video stops randomly at different points after few minutes, and goes back to file explorer. this has never happend before
Installed 1.2.5 again with default 1080p kernel. before the reinstall, the player used to give me lockups during netflix or video's with vertical coloured greenish stripes.
very annoying, video files play fine through the popcorn hourHome Cinema Setup Livingroom:
50" Panasonic Plasma - CS-X806 (s802 1gb/8gb) with Mele F10 on OpenElec 5.0.3 with Kodi - Pioneer Receiver - JBL Surround System - 4TB NAS
Bedroom Media Setup:
32" Philips LCD - KR-42 wasser rom
Originally posted by LeXXoZ View Post... this has never happend before ...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostWith same configuration? Maybe you get a problem with your PSU?
well first it began with the vertical stripes during videoplayback, after the striped screen the box turned off, so i flashed the kitkat 4.4 rom, that one also gave stripes so i went back to 1.2.5 without the OC kernel like i had before, now i dont have vertical stripes but videoplayback just stops and returns me to the file list.
need to test it with other PSU then, i have a 2.5 A laying around here somewhere, but it has a diff. plug so i need to put a new plug on it then.
First im gonna try a reinstall with a OC kernel again to see if that might workHome Cinema Setup Livingroom:
ok i did some benchmarking, psu seems stable enough.....doesnt crash on stressing the thing.
gonna try a reinstall of the rom nowHome Cinema Setup Livingroom:
i think its fixed.... not sure yet.... flashed an OC kernel in stead of the default 1080p one.... now keeps running.
could it be that the default kernel is to weak for HD video ?
And wasser, i installed that driver in /system/lib/hw and set it to -rw-r-r but camera still wont work here
Logitech C270 is the model, after install i rebooted the deviceHome Cinema Setup Livingroom:
Sorry, no idea what's wrong with your device...
If it first time runs fine and than not, I don't think it depends on the kernel...
I use no OC kernel with [email protected] without any problems...
But if it is now fixed, so whatRK3288 Devices
im glad its fixed now hehe i was like, wth whyyyyyy hehehe
but i just played 2 episodes without crashing anymore so im happy againHome Cinema Setup Livingroom:
static mac address
Wasser can you please upload this tool. Thanks
Originally posted by wasser View Postit's my intention to remove my hack for setting mac address in 1.2.5. I found a better solution. You need a new flashtool which allows you to flash the static mac adress. I will upload this tool soon.
wasser
There are currently 1602 users online. 0 members and 1602 guests.
