I'm a newbie when comes to flashing. I own a KR42 with wifi/bluetooth chipset AP6210. I don't know which files do I select and how the flashing going to be done? Appreciate your help and patience...
K-R42 - wasser firmware - JB Android 4.2.2
1. this rom is for devices without bluetooth so the better sub-forum would be J22, GM282, LT88, T-R42, CX919-II
2. BUT to be sure, generally if there exist a custom rom for your device and if yes, which one, you have first to check which PCB/motherboard is at your device
Originally posted by mitchell4you View PostHi,
To figure out what firmware/kernel works for your unit
We first need to know.. what version/revision you have.. this is done by opening the unit
And then looking at the pcb/motherboard
As reference for some models
Note.. to open-up the unit
There are screws under need the rubber-pads of your unit
GoodluckRK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View Post1. this rom is for devices without bluetooth so the better sub-forum would be J22, GM282, LT88, T-R42, CX919-II
Hi
I flashed old version kernel-wasser-k_r42_old-1.2.5
I have a TN-BX09_V2.1 motherboard.
Seems OK... still odd things like
1/ BBC Iplayer only plays on wifi, not ethernet... says something like it needs a network connection to play this page... Plays fine on Wifi,
2/ Netflix never plays HD... only SD quality
3/ Google Play Music still has the one track bug... the following tracks are silent.
4/ sluggish at times and occasional freeze/reboots (4x in one day)
I would like to try the kitkat but it seems there are a lot more things not working, or that require fixes, which I am not too keen on doing.
tx
Mark.
Originally posted by wasser View Postversion 1.2.5
please post your feedbacks, it's very important! and don't forget to report the firmware version you flashed, the revision of your k-r42!_________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
tx
Mark.
I like the 1.2.3 but don't use same apk's like you use.
You also can try some smooth oc kernel (e.g. kernel-k_r42_old_revision_cpu1704_ddr720_1080p_gpu600h)
Maybe you also have a look at UPDATED - Beyond XBMC (Beta 3.4)RK3288 Devices
Originally posted by no_spam_for_me View PostDo you also try the 1.2.3? I have no freeze/reboots with standard kernel.
Hi mate,
Since writing that I tried Kitkat, Q7, now back to lewy 3.2...
But I will try 1.2.3 if 3.2 starts crashing a lot.
Cheers,
Mark._________________________________________
tx
Mark.
I've been using 1.25 since it came out.
I thought that the iPlayer not working over ethernet was quite possibly that it it has been developed to check WiFi and 3G connections only but not having another Android ethernet enabled device to check, I can't be sure.
On boot-up I find it sluggish too but I leave it alone for 5 minutes and then use a task killer to kill off unwanted processes, which then allows it to run smoothly for a couple of hours.
Then I kill unwanted processes again and it's all good for another couple of hours.
So far I have found this the best ROM for the old box and will wait until the KitKat version is perfected before moving.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by bluesmanuk View Post... then use a task killer to kill off unwanted processes ...
Code:adb shell
Code:pm disable com.google.android.googlequicksearchbox
RK3288 Devices
Originally posted by no_spam_for_me View PostI dont't know which tasks you kill, but you are also able to disable (stock) app's:
Code:adb shell
There are currently 4629 users online. 0 members and 4629 guests.
