You can also use old and new rev of kernel and check wifi/lan connection. On fail change to another kernel and You will get yours.
K-R42 - wasser firmware - JB Android 4.2.2
Originally posted by debicho View Post
You can also use old and new rev of kernel and check wifi/lan connection. On fail change to another kernel and You will get yours.X92 3/32 Android TV Box with Ugoos AM3 Firmware
Originally posted by pavlik View Postdebicho There was a lot of boxes with that date so you need to paste "id week date" eg. 1329 / 1340 etc near real date you wrote ... to find out if your box is new or old rev.
You can also use old and new rev of kernel and check wifi/lan connection. On fail change to another kernel and You will get yours.TN-BX09_V2.1 / 1335 / 2013/05/31
Quick faq:
Originally posted by rik91 View PostEverything before 1330 should be old revision, PCB made between 1332 and 1335 has mixed reports of new and old revisions. After 1335 there are rather all new revision PCB.
Generaly speeking there is minor difference between old and new revision concentrating around LAN (Ethernet) controller part of PCB and it is quite safe to install kernel either for old or new revision on new or old version board. Besides LAN everything should work.X92 3/32 Android TV Box with Ugoos AM3 Firmware
For first try new kernel. Check wired connection and if it will not work try old one.
Originally posted by georget View Post....My was born on 1332 (32nd week). And I know 1335 (35th week) requires New 1.2.3 FW. So if your device is with v2.1 printed on board try to check and compare the date of manufacture. Lower than 1332>Old FW, bigger than 1335>New FW.
In case you flash wrong FW version, you won't have LAN in working condition only. "X92 3/32 Android TV Box with Ugoos AM3 Firmware
Ok, I flashed with new kernel and I get correct wifi, but not ethernet. Only I tryed once and now I´m rebooting and try a new chance with the cable connection.
Can be this combination of correct wifi and no ethernet for a incorrect kernel version?
EDIT:
I flashed old kernel and I have same issue. I get wifi when besides router, but I don't reach when in hall.
And I don't have ethernet signal.
So the problem it's the same with new or old kernels. I´m tired from this device.Last edited by debicho; 11 May 2014, 10:46.TN-BX09_V2.1 / 1335 / 2013/05/31
Originally posted by debicho View PostAnd I don't have ethernet signal.
The problem is, that the ethernet implementation don't use a static MAC...
So maybe it helps to setup the IP and so on at the box...
Maybe also try the 1.2.3 (like I use)RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostReally no ethernet signal or do you use DHCP at router/box?
Maybe also try the 1.2.3 (like I use)TN-BX09_V2.1 / 1335 / 2013/05/31
I don't know at router, but do you try to config the ethernet IP and so on manually at the box?
(And, I think, at the router you have to configure the DHCP only to use IP from e.g. x.x.x.002 ... x.x.x.100, and use at box an IP > x.x.x.100)...RK3288 Devices
Hi Wasser,
I am using your 1.2.5 Rom with CS918, however I found the IR remote doesn't work and the stock remote is a bit different from others. Can you help me or what I should do to make the IR remote work properly?
P.S. (I found that lewy24001's 1.2.0 rom's kernel support this remote, but if i flash its kernel to your 1.2.5 rom, the system hang after 1minute of boot (which i can see the launcher only then hang....))
Thanks,
tmac666
There are currently 3904 users online. 1 members and 3903 guests.
