I don't know how some other users reported that they did it...
Pipo M7 Pro RileyROM 2.1.1
Does anyone know the problem?
The tablet has shut down completely and can no longer be started.
Short or long press the power button it does not respond.
Only when the Power Supply is connected it works.
Battery is fully charged and the button works (Screen off, on, etc)
Apparently has nothing to do with the Rom version
THX
Trax74
have you tried the reset button at the back of the tablet. you need a toothpick or a paperclip to press that.
Happened to me several times that the tablet wont turn on via the power button, tried holding the reset button for about 5 sec then release and press power. worked for me.Proud M7Pro owner and Freaktab fan
I've found that when they are brand new, the power buttons tend to be stiff. It took about a week to wear in the one on my M7 Pro and M8 Pro before they worked right.
RandyRandy
Originally posted by val_andrio View PostFirst of all I want to thank you for your effort on boosting up our favorite tablet. You have done a great job till now.
I have a question also. Did anyone tried skype? It seems to crash sometimes, the mic is not always working and the camera is sometimes up side down. Do you guys have those problems too?
Skype calls was on of the top reason that I bought the tablet so it's real important to me.
Let me know.
Originally posted by Dennta View PostThe first time user guide stresses that you always should erase IDB. But now charlesmouse have installed his roms without doing this and therfore not having to install everything from backups. Why should you erase IDB everytime? Can you take a nandroid backup and try to install a new rileyrom without erasing IDB without any risk?
Its not really a problem installing everything from backups, but its a little frustrating having to re-do the layout on the homescreen every time
with "Mybackup root", you can save and restore it
Sv: Pipo M7 Pro RileyROM 2.1.1
Skickat från min M7pro via Tapatalk 2
Originally posted by manao View PostIf you use an alternative launcher try "Nova launcher" or "Apex launcher" and you can restore your homescreen backup (icons - folders and dock) after you have updated your tablet.
They are clean launchers.
You can uninstall the launcher normally like an app
With "Nova" you can import the layout from an other launcher or from itself.
The best is to try the application
If you use the standard Android launcher and you want backup your homescreen and other things, "Mybackup root" is a good idea.
Originally posted by Dennta View PostHow do you backup your layout with this? Do you use this to do all your backups or just for layout?
here are some explanations: http://blogs.computerworld.com/16256...d_home_screens
Originally posted by ef98dpa View PostHave anyone had problem with a flashing screen? Mainly the "menu bar". Is it different with this rom or any of the later? I am at 1.7a at the moment.
Stock august firmware there, no any firmware update was applied yet.
Does anyone want to try?
Attached kernel is working for me with 720 MHz RAM and 1704 MHz CPU.
It passes AnTuTu test having 20590 score in ondemand mode and 20861 in performance.
kernel_cpu1704..zip
There are currently 4346 users online. 0 members and 4346 guests.
