Pipo M7 Pro RileyROM 2.1.1
I've modified rkpatchomatic script keeping all M7 stock CPU frequencies + 1704 MHz and discarded one intermediate (1200 MHz?) which never been used. I'm keeping in the table original voltages from stock kernel too.
This kernel is modified one from October 28th official stock ROM.
I have no other benchmarks at the moment installed. Probably will try later just for fun.
BTW, tried video sync mod just to test it as well once again and get a dark screen, seems that video driver is modified in stock kernel now.
Originally posted by dianne.abena View Posthow to properly install thev 1704h kernel fazerg uploaded?
For those using stock ROMs #6 and newer modified boot.img needed too. It should not contain embedded kernel.
Originally posted by dianne.abena View Postwell it booted on mine for a minute and passed the lock screen,and then bootloop again,maybe i need a clean install,i guess
Originally posted by ef98dpa View PostHave anyone had problem with a flashing screen? Mainly the "menu bar". Is it different with this rom or any of the later? I am at 1.7a at the moment.
I just released a new ROM today for the M9 Pro. v2.1.
The new ROM works on the M7 Pro tablet if you flash one of the M7 Pro kernels and M7 Pro recovery.
An interesting addition is a button on the button bar that will hide the button bar. Just swipe up from the bottom and the buttons return.
I've added two new features, myself. Thanks to my fellow developer 900Supersport. We've been testing his new kitchen app and thought they would improve things a bit:
1. After first boot, the system automatically installs CWM Recovery. It uses stock recovery to format everything correctly then flashes CWM Recovery in it's place. So you will notice that I've removed cwmrecovery.img from the kit (it isn't needed anymore).
2. You can automatically install apps (on first boot only) by inserting an external sd card with a folder named autoinstall. Just place your apk files in that folder. Make sure there are no spaces in the apk file names, or they won't install. Most apps install pretty well. Some paid apps, like Titanium Backup cause some problems if you try to install the key app this way.
Just remember to use an M7 Pro kernel. Since a kernel is embedded in recovery.img...I would also recommend flashing the M7 Pro recovery.img instead of the one for the M9 Pro.
I just found this out by accident and thought I would share.
I got a 19946 Antutu with the stock M7 Pro kernel.Randy
Wow! Thank you Randy for this update but I have few questions before I try the 2.1 rom for M9Pro.
Is it necessary to change the M9Pro recovery to m7pro 2.1.1's recovery? What if I still install the recovery from the M9Pro and just get the kernel of M7Pro, is there a risk of bricking?
Please correct me if I didn't understand the process that I should do:
1) Rom Flash tool in M9Pro 2.1 > change kernel and recovery to m7pro's 2.1.1 kernel and recovery.
2) Reboot to flash > Erase Nand > Flash Rom
Thank you very much.Proud M7Pro owner and Freaktab fan
Hello World
Originally posted by manao View Post1) Rom Flash tool in M9Pro 2.1 > change kernel and recovery to m7pro's 2.1.1 kernel and recovery.
Stock rom is 2013.10.28.195622 ... after few test I got a black screen and I had to press reset so I'd like to update it with RileyROM. (M9Pro 2.1)
Here the question:- Any easy way to flash it on linux ?
- change kernel and recovery -> file names (recovery/kernel) ? ( sorry I'm a kind of newbie )
- download both roms ( M7 and M9)
- take kernel and recovery from the M7 and put it inside the M9 ROM
- Flash with the tool
Thanks you very much for your work Randy !!!
Actually, the M9P recovery did work on my M7P. It is just safer to use the kernel designed for a specific tablet. That's why I recommend using the m7 recovery.
Be sure to erase IDB before flashing a new ROM version to reformat everything.
RandyRandy
There are currently 2125 users online. 1 members and 2124 guests.
