I managed to screw up my 701i and I had to reflash the rom. I used the "stock 701i rom" and when I tilt the screen, it rotates backwards. I tried to reflash several times and the problem is still there. The only way I can use the tablet is to set it on a flat surface.
I flashed the 701c ICS rom onto my 701i and the problem is gone. I am wondering if this is common. Also, is there a problem running the 701c rom on my 701i? Are they basically the same rom?
