A logcat would help...
SPMC
Originally posted by sawbones999 View PostWhat is the date of the ROM?
Cheers,
-SB
Originally posted by billyme View Post
You should be able to adjust color, saturation, brightness, etc with an external app if necessary, or as a last resort on your tv.
If I I'm incorrect about this, someone please correct me, because if there is a fix I'd like to know it, too.
With your firmware release date being what it is, you should have the most up to date libs already. If you want to double check, then compare the sizes of the video libs against the ones here in the firefly bitbucket https://bitbucket.org/T-Firefly/fire...lib/?at=master
It took me forever to find those again, lol. You might want to bookmark that page for future reference.
On another note, I'm having a problem with SPMC 14.1 on my ADT-1. The problem is that I can't adjust the volume from within SPMC. I have tried using the right stick up and down, also from the menu to adjust audio while a video is playing and no matter what the indicator says about the volume level, the output remains constant.
I have tried with audio pass through on and off and it makes no difference. I'm pretty sure it was like that in recent betas as well. I don't think I tested it when I was briefly trying out KODI 14. I would like to say that I know it can be adjusted in other apps, but I'm actually not certain I've tested that. Maybe once with Pandora or Pluto tv. My ADT-1's primary function is SPMC with a little gaming on the side.
Does anyone know of a fix for this? It's not a huge deal or anything, but I like to have a bit finer control over the volume.
Thanks again for all your hard work, koying! We all appreciate it very much.
Cheers!
-SB---------------------------------------
Currently using U-BOX R89 with mo123 v1.6.
Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
Pipo M9S -- CrewRKTab custom rooted 4.4.2
RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
I have a quick question for you, koying. I've been looking through your github, and I was just wondering which version of ffmpeg we're on now. Both on 14.1 release and latest alpha (i think there is a new alpha? Maybe not). Just being curious.
But am I correct that the version included will only affect software decoding, or are there improvements in hw acceleration as well?
Then also, I was wondering if in using rklibstagefright, then I would be stuck with the newest version Rockchip is using. Or would that only be true if using rkffplayer, and then only if rkffplayer was specified in playercorefacory, which it is not, right?
I'm full of questions today, trying to learn as much as possible so one more. On ADT-1, if I could find newer tegra 4 libstagefright and other related libs, would there be any benefit to using those instead? Will the better benefit to tegra 4 come from the updated ffmpeg in the newer KODI that allows software decoding of more codecs like h.265 ?(I have no idea what kind of quality that would be, but heard it's happening).
Sorry for all those questions. Thanks for your time!
Cheers,
Originally posted by Koying View PostIs it happening with other files? Someone else noticed something similar?
Thanks!
-AaronTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by sawbones999 View PostWill the better benefit to tegra 4 come from the updated ffmpeg in the newer KODI that allows software decoding of more codecs like h.265 ?(I have no idea what kind of quality that would be, but heard it's happening).
-SB
On a full blow CPU like an Intel Core I* processor software decoding is indeed possible as there is excess CPU power to decode these types of video files.
Originally posted by choekstr View PostAndroid based hardware just doesn't have the CPU power for software HEVC/H.265 decoding without hardware gpu support. Expect to get around 3-10 FPS using software decoding for H.265 vs 23.98-60FPS for HW decoding.
At first he was claiming h.265 4K at 1080p, full frame rate. Then he tried to say it output at 4K. Then he revealed that the ADT-1 could do h.265, using serverwmc Windows backend to decode and stream to his ADT-1. He claims this as native support with a work around.
Just because it will stream to the ADT-1 as a wmc client that hardly means that ADT-1 is capable of decoding it on it's own. I finally decided to ignore it, because every time I pointed out a flaw in his logic he comes back with wilder and more senseless responses.
-----Back on topic
Has anyone else had the same issues with audio output on ADT-1, or know of a way to adjust the audio inside SPMC. I don't have this problem with SPMC any other device.
Cheers,
I just tested it with software decoder to see if it's a libmedia or libstagefright issue and the result is the same. Can't adjust volume.
Cheers,
Ah, well then there is another reason why I like my R89 more than my ADT-1. I like having the ability to adjust the volume as well as playback with the same input peripheral.
Plus it's just not fine enough sometimes at the tv. My 1yr old daughter's bedroom is next to the living room and sometimes I am up very late at night watching tv and I'm the only one in the house awake. I may be watching a kung fu movie or something dubbed and the dialog might be low so I'll have to turn it up, then the fight sequences or music may be louder so I have to turn it down.
But if I can control the volume at the source, not only do I not have to juggle remotes, but I often am able to reduce the source volume and find just the right spot between the volume numbers on my tv where I won't have to adjust it at all, or as much.
At 4 am when there is no outside traffic sounds, the heater is off, and everyone in the house is asleep, volume # 4 can be loud on the tv when the source is at 100%, but then 3 is not loud enough to understand the dialog. When you can tweak the source volume there is a sweet spot.
I guess I'm just used to that, because even before I got my r89 and before I got into XBMC, I used to use a pc for Netflix/downloaded movies and had the same issue. Of course on a pc it's no big deal to tweak the volume however you like it before it hits the tv.
Thanks for the reply!
Cheers,
http://www.freaktab.com/showthread.p...irmware-v1-02-)Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by sawbones999 View PostAh, well then there is another reason why I like my R89 more than my ADT-1. I like having the ability to adjust the volume as well as playback with the same input peripheral.
Cheers,
-SB
I had no idea that volume wasn't a feature on some of these boxes. Ugh, makes me happy my pipo x7 win8 STB also supports volume as well.
There are currently 2048 users online. 0 members and 2048 guests.
