SPMC
thanks for the new version, I thougt the new version will solved my problem, but it's still the same with the tvheadend, the playback I still black and I hear only sound, I don't think tvheadend have support for rk3288 chip and other rk because the problem come from the RKlibstagefright and it's must be unchecked if I want play channels normally otherwise I get black playback
Originally posted by Koying View PostJust did a quick 3288 test with iptv and is working fine. No tvheadend setup here.
P.S. Indeed, don't know if it is a borked update or something, but the forum is over-slow and over-ugly
Yes the simply ip tv client work for me to, it's only the tvheadend I have problem with black playback, but when I unchecked RKlibstagefright the tvheadend work like a charm, I don't think many people use tvheadend especially on android it why maybe it not a known problem with that I have, I have search about this to see if any have the same problem but I couldn't find anything.. If you want a setup for tvheadend I can give you so you can test it
Originally posted by Shadi86 View Post
Updated
I've had a very similar problem (Aus TV stations use MPEG2), however, with earlier versions of SPMC, RKlibstagefright and libstagefright would cause SPMC to crash.
Later versions would result in a black screen with sound.
I sent a few logs to Koying back in January.
I don't know if it can be solved, so have just been using MediaCodec.
Originally posted by Koying View PostP.S. Indeed, don't know if it is a borked update or something, but the forum is over-slow and over-ugly
+100
.......and a slower, pain in the arse to navigate.
Originally posted by Koying View PostSPMC 14.2.0 published: http://spmc.semperpax.com/
after the first screen boot , i have blank screen , i can hear touch sound , but black screen
Same issue with kodi 14.2 to 15 alpha
Only kodi 14.0 work without problem
Could you help me ?
thank you
Originally posted by freddy_krueger View PostPlease help me i cant use spmc or kodi
When i launch it, i can see first launch screen and after that nothing !
Totally black screen, no menu, no interface
I have only clicks sound
Only version that works Is preinstalled kodi 14 rc
Thanks for your help
Alessandro
I'm very new to SPMC or even Kodi. I have just installed the SPMC 14.2 to my MK808B+. When I attempt to watch videos via any Video Addons, I only get the videos to play letterboxed in the top left corner, about 1/4 of the screen. The only adjustments that happen when I select the various formats (4:3, 16:9, Zoom, etc..) is the letterbox size is altered slightly. The MK808+ is connected to my 108P TV via HDMI output.
I've done a google search and also on the this forum and can't find how to be able to see the video full screen.
Any assistance is greatly appreciated.
Originally posted by TerryH View PostI'm very new to SPMC or even Kodi. I have just installed the SPMC 14.2 to my MK808B+. When I attempt to watch videos via any Video Addons, I only get the videos to play letterboxed in the top left corner, about 1/4 of the screen. The only adjustments that happen when I select the various formats (4:3, 16:9, Zoom, etc..) is the letterbox size is altered slightly. The MK808+ is connected to my 108P TV via HDMI output.
Originally posted by smokie171 View Post
Video overlay needs to be set to 1. I believe that earlier in the thread this is gone over. I did this several months ago and can't remember if that is all. You will need to use build.prop editor to change the value from 0 to 1.video overlay=1. Read the thread bc there may be another line. Good Luck
Originally posted by Ico747 View Post
Does not work with RKlibstagefright enabled on my X7 Neo with oficial X7 Kitkat 230.
Originally posted by skazza View Post
You must have to disable Rklibstagefright,that is for Soc Rk3288Last edited by smokie171; 04-11-2015, 17:42.
There are currently 1131 users online. 7 members and 1124 guests.
