1) I correct the first post so it says 1.8 above the download links. Thanks for letting me know. That's what I get trying to save time and cut and pasting from the 1.7 post.
2) Home screen lag. I had not noticed it. Is it just the center screen or do all screen of the launcher lag? Minix put in some garbage APPS in the provision service I removed. The launcher was hiding those APPs. On this 007e release I did not replace the launcher this time as I did not see those apps anymore. I bet if you took the launcher I rebuilt from my 1.7 ROM and put it in 1.8, the lag maybe fixed. If someone is willing to try this, I will provide the launcher.
3) When I compared the files from 007 to 007e MANY and I mean MANY files were updated by Minix. Framework, APPS, libs, etc. So yes there is a significant difference.
4) Whenever you get download failures from Google Play, make sure your time is set right!!!! This is a know issues. On first boot your time might be 1970. So either connect and if your router updates time great. If not set time manually.
5) Sloppy? I have always been a little sloppy
6) Hard drive un-mounting. Unfortunately this has been an issue with Google AOSP since 4.1.1. Why this got removed is beyond me. It use to be in Gingerbread. Most people use the free Mount Manager APP to unmounts hard disks.
I think I got most of the questions?
