Try to reflash
Minix Neo X7 - Finless 1.8 ROM
Re: NEW - Minix Neo X7 - Finless 1.8 ROM
Originally posted by Finless View PostFor now get extended settings from Google Play. It should give you access to features Minix took out of settings. I will look into the screen saver thing but by default it is set to off in build.prop so I am curious as to why this is happening.
Originally posted by strix View PostI have this on my T428 and all is good except for wifi. 1080/1704/600gpu and 667ddr
Try to reflash
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
there is only a option for screen time always on
i think they disable it in the apk itself
and most of the tweaks that people use are bull
90% of those tweaks are making it even worse the better
Originally posted by sebastiaan15 View Posti looked myself and there is no option in build.prop that the screensaver is default set to off
In fact, i found ro.rk.screeoff_time = -1 in build.prop. I think is related to time to launch screensaver.
I edit to 12000 (This is in milliseconds), reboot, and this not working.
Maybe someone to fix that?
Originally posted by roolmapool View PostIn fact, i found ro.rk.screeoff_time = -1 in build.prop. I think is related to time to launch screensaver.
So this is not the normal Android "sleep" or "screen saver" we are talking about. As Leolas said it must be some kind of HDMI sleep and is new by Minix or RockChip.
Xbmc reinstall
Hello, I tried the XBMC Minix app with Finless 1.8, it was working great, but I installed too much add-ons so I uninstalled it to clean up the mess. I reinstall it but now the add-ons won't download and Xbmc gets stuck when I try to exit. Is there a way to completely delete xbmc or is there some hidden data folders I can delete?
Originally posted by macgreo View PostHi...
maybe you can help me... I cant use OTG port, its break. Can I update from 1.7 to 1.8 with SD card, wifi,.. ?
thx u!
Stutter
Originally posted by sbarriba View PostSo I just tried with (long) LAN cable to prove if I can exclude the Buffering and give you a definitive answer on MKVs.
Using a LAN did avoid ANY buffering but I was disappointed it isn't quite perfect. You get the odd v minor stutter here and there - maybe every 90 secs or so.
Duration: 02:11:14.91, start: 0.000000, bitrate: 26693 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Stream #0:1(jpn): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 768 kb/s (default)
More tuning to do then.
so i was verry happy with the new release from minix but it was worse then bob came with 1.8 but it is stil not smooth it's stable tho and that is a big relieve
So i'm stil hoping that someone finds a solution
Hmmmm... if you look at the file init.rc you will see I increased the buffer size in one area that I have always done on TV stick ROMs to improve streaming performance. I wonder if this is effecting anything this go around?
Unfortunatly the average Joe cannot edit init.rc as it is in boot.img. If someone wants to test stock buffers I can make a boot.img without this change?
Originally posted by Finless View PostHmmmm... if you look at the file init.rc you will see I increased the buffer size in one area that I have always done on TV stick ROMs to improve streaming performance. I wonder if this is effecting anything this go around?
I have found the file init.rc but i can't open it too edit schould i use root explorer ?
I can now open the file with root explorer but it seems to be empty
Originally posted by GreekSoldier View PostHello, I tried the XBMC Minix app with Finless 1.8, it was working great, but I installed too much add-ons so I uninstalled it to clean up the mess. I reinstall it but now the add-ons won't download and Xbmc gets stuck when I try to exit. Is there a way to completely delete xbmc or is there some hidden data folders I can delete?
Originally posted by mcln27 View PostOk Bob i managed to open the file so i can edit it
There are currently 2313 users online. 0 members and 2313 guests.
