Minix Neo X7 - Finless 1.8 ROM
It seems that the problem with my rc11 air control exist only in 1.8 finless rom. I tried stock 007e - quickshot - neomod rom and only in finless my rc 11 is not working good. I flashed twice for the records. what is the file for these drivers? bob please help. I want to use only your rom, as i think it is the best!
Originally posted by ptiper21 View PostIt seems that the problem with my rc11 air control exist only in 1.8 finless rom. I tried stock 007e - quickshot - neomod rom and only in finless my rc 11 is not working good. I flashed twice for the records. what is the file for these drivers? bob please help. I want to use only your rom, as i think it is the best!
It doesn't make sense.
Originally posted by Finless View PostThat is odd.... I changed nothing from 007e to make a controller not work
Are you willing to test and work with me on this?
I need you to know how to use ES file explorer and copy stuff where I tell you. Advanced enough to try?
Originally posted by Finless View PostHmmmm I wonder if removing the secret APP bleProximity.apk has something to do with it?
ok i could test it. i use es file manager with root permission. i wait your instructions. thanks
Originally posted by ptiper21 View Postit is working but it is not smooth. inside apps like xbmc, settings etc it stucks for 5 sec or more.
So it works but some problem? Can you explain in more detail please?
What does it sucks for 5 seconds or more?
Originally posted by Finless View PostOK wait... that is different than I thought. I assumed it did not work at all?
installed and working good so far. Switched to the stock build.prop and put the new MINIX xbmc beta on. Seems to work well.900Supersport
freaktab developer
Originally posted by Mikael View PostJust out of curiosity and totally off-topic. How does the stock player in Minix play passthrough if it does not require the libmedia.so fix?
Originally posted by magno View PostI guess passthrough it is possible since no royalties are applied.
The consequence: The stock video player (and e.g. MX Player without the custom codec) are only able to play DTS soundtracks in passthrough mode.
Originally posted by Molle View PostExactly. Royalties apply only if the bitstream is decoded. Passthrough just "passes through" the digital stream unaltered to the sound output device. That's why e.g. volume controls can't be applied to sound in passthrough mode.
Ok, I haven´t looked into it deep enough to land in a conclusion if he made the reference only in relationship to XBMC and how it plays streams, but I assumed that he did not and was pointing to the actual APIs of Android in general not supporting passthrough.
So, unless the stock player and the MX player without the custom codec actually uses unsupported API calls to play these passthrough sound files, then there is already support built into both Android and the X7 to support it?
And if they do indeed use unsupported API calls. Maybe that way to solve the passthrough on the X7 is a better way of solving it all together instead of a modified medialib.so that only introduces more "alterations" of the Minix version of the OS? Why solve the same problem twice - especially if it has been working great with the MX player /stock player for a long time already.
There are currently 2077 users online. 0 members and 2077 guests.
