Have you tried the latest ROM from Minix (oficial) ?
Minix Neo X7 - Finless 1.8 ROM
Originally posted by welcometopoland View PostCan anybody help please ?
Apparently this was fixed by MINIX, but.. whatever I do I still get micro-freezes when watching 1080p mkv
Tried various XMBC versions, tried MX Player, tried 1080/24 and 1080/60 setting.
No luck.
I want 1080p for the movies, but also for watching hires pictures, so going to a 720p kernel is not a thing I want.
Originally posted by snorhyvel View PostHi.Thanks for this nice ROM. I have some problems though. When I use explorer and chose network places it first works fine, but then the second time it complains about the password, and I see that the path it tries is not correct, it adds some other path and say access denied... I think I had this problem with the stock ROM as well...
I have been putting together an xbmc for my own use and to install on all my families boxes and I know how much you lot love to mess with xbmc so I thought I would share and you can help me find any bugs I have missed lol.
Some of the things that should work.
- Hardware Decoding
- Mouse wheel support
- New Graphics (Not finished yet)
- A fully customizable version of Confluence skin as default. All other skins removed. (If you want it faster then enable minimum spec option in skin settings)
- Audio offset by 250 ms to fix audio lag.
- SuperRepo Included.
- All addons brought up to date.
It takes a long time on first run (about 2 minutes) while it sets everything up. The screen will go black and then it will go thru a few backgrounds, Just wait it out. It will launch normally after the first time.
Let me know how it goes.
Beyond XBMC Beta 1Last edited by Flumpster; 05 January 2014, 15:43.To Infinity and Beyond.... XBMC
Pluto,
thanks for the info. I have Lenovo N5902 remote and it unfortunately emits random back event not only during movies but also during normal use (tunein radio, wimp , chrome, google+ etc.)
replacing batteries and changing usb dongle slot didn't work for me
Is there anyone else who has had this issue solved ?
Originally posted by Pluto View PostThe random "go back" funtion is back. i know a few people had this, but strangely it happens only during movies.
While watching movies, i am just returned to the previous screen before the movie, first i thought it is dropped packets or buffer overload, but it was not a network issue. It is definitely not an app crash since no FC show up.
I found something even more awkward, it only happens to me when the minix remote is facing minix. took the batteries out, and could watch the movie without being interfered. WTH?
PS, to Bob and all Logitech k400 owners, are you having any sort of issues. Rapid typing makes the minix dyslectic, and sometimes the last touched key just continuely inputs yet the key is not held, very annoying when it happens with the backspace button.
Maybe it is coincidence but worth a go.
Edit.. I missed the part where you said you have tried other usb slots sorry.To Infinity and Beyond.... XBMC
Originally posted by adrenalize View PostUnfortunately not, it needs the lock screen working to switch users - it is based on the Minix ROM which seems to only have the lock screen partially implemented and not just hidden. Bob says it isn't a simple job to fix unfortunately.
Multi user would be great for me also as I use it as a big touchscreen in the kitchen with several of the family using it.
Scribed henceforth from thy G pad.
Originally posted by DeliriumNL View PostHi Bob,
I'm i've been using Finless 1.7 and 1.8 for a while now. Since a couple of days - out of nothing - my box randomly shuts down.
This can happen during a youtube video, xbmx or anything else. It's completely random and happens once or twice per hour. Needless to say it's a big annoyance.
I'm using the following equipment
- Logitech K520
- USB DAC for audio-out.
- Toshiba TV
- Finless 1.8 with stock no-air kernel and no OC.
I had this problem both on 1.7 and after flashing to 1.8 it remained. I did a full NAND erase.
Any advice is welcome, is my device broken? I never oc'd it. Always run stock finless.
Thanks for your time.
Nice I will try this out.
Is this based of the new Minix x7 Version or the beta 2??
Some of the things that should work.- Hardware Decoding
Beyond XBMC Beta 1
Originally posted by unlo View PostWhat touchscreen did you have it working with? Interested in trying one out as well exactly as u described.
Lots of of info in this thread http://www.freaktab.com/showthread.php?1802-Touchscreen
There are currently 2450 users online. 0 members and 2450 guests.
