Quick question before I take a deep dive into Android kernel compilation. Does Android use loadable (.ko) kernel modules or do drivers have to be compiled into the kernel? Thanks in advance.
Minix Neo X7 - Finless 1.8 ROM
NOOB kernel question
Guest
Random shutdowns
Hi Bob,
I'm i've been using Finless 1.7 and 1.8 for a while now. Since a couple of days - out of nothing - my box randomly shuts down.
This can happen during a youtube video, xbmx or anything else. It's completely random and happens once or twice per hour. Needless to say it's a big annoyance.
I'm using the following equipment
- Logitech K520
- USB DAC for audio-out.
- Toshiba TV
- Finless 1.8 with stock no-air kernel and no OC.
I had this problem both on 1.7 and after flashing to 1.8 it remained. I did a full NAND erase.
Any advice is welcome, is my device broken? I never oc'd it. Always run stock finless.
Thanks for your time.
Originally posted by adx7 View PostI tried MX player, BS player, XBMC several versions. Don't get me wrong, hardware decoding is working on (mostly) everything I tried; without it no way to get 1080p decent playback.
The playback in 1080p is (somehow) fine, however, at a closer look, there are some small "stops" every 2-3 seconds, hard to see, it's true. It is most obvious when there is something scrolling on the screen, like credits at the end of movies, or the text in the beginning at Star Wars.. I compared the scrolling with the playback of a (powerful) PC and with a cheap media player, when the stuttering does not occur. Call me too ambitious trying to get things perfect.
However, there must be some way to clearly identify this, meaning some counter or report of dropped frames, but I don't know how to get it. The only thing I managed is to get the info in BS player and after some 20 minutes of playback of a [email protected] I got a frame rate (reported by BS player) of 23.8. But I'm not sure if this a relevant test...
PS: Right know I'm using Nitroteam Quickshot with 1080p_1800_gpu798_ddr800 kernel from Molle http://www.freaktab.com/showthread.p...and-overclocks and I am seeing a small improvement. Flashed kernel a day ago, watched a movie, fiddled with xmbc (skins/settings).. no crash so far.
I have also an other problem which I didn't solve yet. Anyone advice?
All right, I was beginning to think I am the only "freak"(taber) noticing that stutter. But is this a problem that could be resolved via software or it is because of the hardware?
I am an IT specialist and I like to tweak things into getting the most out of the hardware, but I am not so familiar with the chips and hardware specs of that box. I am also willing to try any new things and tweaks to get that fixed.
I tried mostly everything I could get my hand on, Finless 1.6-7-8, Strauzo's, Lewy's, Quickshot. All behave the same. So, this could be a hardware issue or all those ROMs are based on the same software "thing", namely the kernel. Perhaps a new kernel version would change this.. to better, hopefully?
I would try and compile a new version, does anyone know where to grab a new kernel?
Originally posted by Koying View PostIf you have stutters with all players AND you have a Samsung TV, check the "Motion compensation" settings on your TV.
It's buggy. Apparently, setting it to "Clear" seems to work best.
Hej guys.
I want to mount my nfs share with busybox mount -o nolock,ro -nfs ....... That works great great.
Anybody know what command i must use to automount at startup?
My commandline is
busybox mount -o nolock,ro -t nfs 192.168.1.15:/Multimedia/Video /sdcard/mnt/nfs
The one that helps me gets a free case of Heineken beer!!! Yeah!!!
Sent from my HTC One using Tapatalk
make use of init.d support.
using esfileexplorer make system RW
then broswse to system/etc/init.d and create a new text file named 017mountnfs
open this as a text file and edit
add the following line then your mount instruction.
Code:#!system/bin/sh your mount line here
900Supersport
freaktab developer
Re: NEW - Minix Neo X7 - Finless 1.8 ROM
Yes900Supersport
freaktab developer
Originally posted by 900supersport View PostYes
I made a file named 017mountnfs
Does it need .sh after 017mountnfs
With es file texteditor i made the #!system/bin/sh
And saved it.
Reboot and the share is not mounted..
Please advise.
Originally posted by benster1 View PostWith es file texteditor i made the #!system/bin/sh
Code:#!/system/bin/sh
There are currently 1707 users online. 0 members and 1707 guests.
