Minix Neo X7 - Finless 1.8 ROM
I use a K400 myself and the only time I get lag is when the keyboard is far away or the signal is being blocked by something like my body! Please test with the K400 closer to the box with no obstructions and has good batteries! Also make sure the USB dongle for the keyboard is not blocked by the TV and has clear sight to the keyboard! I put mine on a USB hub and this solved weird lag problems by getting it away from the wifi antenna.
As if the tables have turned.
At first install and first boot, i had the green nuances (pixels) all over the desktop, now its fine.
Now it is screen changing thats horrible, even with the X7 remote that comes with it. Mind you that i use Apex, but i always have and never had this much lag. I have flashed the least overclocked kernel in all areas, minimum OC at CPU/GPU/RAM.
Also just had a shutdown while moving around the Settings page.
ps, Bob you should include some basic APK's, at least something for the DPI.
Re: NEW - Minix Neo X7 - Finless 1.8 ROM
Originally posted by G@Shorty View PostHello,
does anybody know if i can flash the original Minix 007e Kernel to this this ROM. Because I need eighter NFS or CIFS support in the Kernel.
Greetz
G@Shorty
Enviado desde mi GT-I9505 usando Tapatalk 2
Beutiful rom
For first congratulations for your great job. With this rom minix starts to be a good device.
I have two problems:
1) my video projector doesn't have a timer function to switch off itself while hdmi port is in use,
can I set sleep function of x7 to only switch off hdmi out instead of normal sleep function or something similar?
(I set sleep timer after 5 minutes but I want it only switch off hdmi out).
2) I need AirPin app and I have installed 720p kernel with it but after some minutes it tells me the app is something like cracked and doesn't work anymore. Does it depend because "device will show up in google play as Samsung device not a X7" modification?
Thanks in advance,
Originally posted by Mikael View PostAnd if they do indeed use unsupported API calls. Maybe that way to solve the passthrough on the X7 is a better way of solving it all together instead of a modified medialib.so that only introduces more "alterations" of the Minix version of the OS? Why solve the same problem twice - especially if it has been working great with the MX player /stock player for a long time already.
BTW, I tried overwriting Finless 1.8 libmedia (the hacked one) with Finless 1.6 libmedia (not hacked) and I still haven't got DTS passthrough... I can't believe I'm the only man on Earth who has this problem...
Originally posted by nitro82 View PostFor first congratulations for your great job. With this rom minix starts to be a good device.
Thanks in advance,
Originally posted by gswiatl View PostRe item 2, you need to email the airpin app owner (email is inside the app). You need to let him know that you are using an original Minix box with a custom rom that is spoofing the device name and also let him know your box's mac address (the one you are using - wifi or ethernet or both). He should then authorize your box in his autohrization server.
Read the README!
Or read at least the last few posts over the last 2 days. Please spend some time looking rather than expecting an instant answer that has already been answered!
Someone shoot me... I get tired sometimes of people that wont do the research!
It gets old...... Sorry.....
Read the README!
ok flashed the kernal and we are good. previous one could do both without a kernal change. Still have some mouse lag.
Guest
Originally posted by Finless View PostI use a K400 myself and the only time I get lag is when the keyboard is far away or the signal is being blocked by something like my body! Please test with the K400 closer to the box with no obstructions and has good batteries! Also make sure the USB dongle for the keyboard is not blocked by the TV and has clear sight to the keyboard! I put mine on a USB hub and this solved weird lag problems by getting it away from the wifi antenna.
My experiences so far:
- A2 airmouse: structurally unusable at any distance
- Logitech K520 working fine but sometimes keys get stuck
- Tascam USB DAC: Compatability is great, works great, but performance is unstable with pops, crackles and recently (2-3 days) it started to crash the box. (???)
- I have a Mele F10 Pro coming in soon, will report on that too.
I'm still on Finless 1.7 though, stock, air. I will upgrade in January after my holiday to Finless 1.9
Originally posted by magno View PostThat's a GREAT question that got me confused. I hope somebody read this and can tell us.
As you probably know from other conversations, I mostly use XBMC here at home, So I do not have as many hours experiencing the stock player or the MX player, and I also have not had the opportunity to run a ROM for a longer time that does not include the libmedia.so hack since I bought my X7s quite late.
Do you run passthrough with HDMI or optical?
Have you tried simply to revert back to the Finless 1.6 you ran earlier without issues just to verify that everything works "out of the box" there again?
Bit of an effort to do so, but I imagine it would send a clear signal to the community that something has changed in later ROMs that break how Rockchip and Minix used to solve the passthrough earlier on at least SOME of our X7s.
There are currently 2692 users online. 1 members and 2691 guests.
