i have an issue on finless 1.8 rom running on x7, i'm trying to see if its a know issue and if anyone knows a fix?. I installed hulu plus, it boots up correctly takes u to the main hulu page but when u select something to watch it'll start to load but before any video plays the whole unit shuts down everytime. after unplugging it for the 10secs it'll reboot but if i go back into hulu it'll do it again same exact spot. Any ideas? if i should post a log tell me what to do to retrieve it. thanks
Minix Neo X7 - Finless 1.8 ROM
hulu issue
i have an issue on finless 1.8 rom running on x7, i'm trying to see if its a know issue and if anyone knows a fix?. I installed hulu plus, it boots up correctly takes u to the main hulu page but when u select something to watch it'll start to load but before any video plays the whole unit shuts down everytime. after unplugging it for the 10secs it'll reboot but if i go back into hulu it'll do it again same exact spot. Any ideas? if i should post a log tell me what to do to retrieve it. thanksLast edited by ebrown761; 14 December 2013, 15:15.
same here on T428
Same for me on t428
Originally posted by ebrown761 View Posti have an issue on finless 1.8 rom running on x7, i'm trying to see if its a know issue and if anyone knows a fix?. I installed hulu plus, it boots up correctly takes u to the main hulu page but when u select something to watch it'll start to load but before any video plays the whole unit shuts down everytime. after unplugging it for the 10secs it'll reboot but if i go back into hulu it'll do it again same exact spot. Any ideas? if i should post a log tell me what to do to retrieve it. thanks
Hi Bob and all. After flashing the unit with a specific kernel and install many apps, but also would like to try other kernels to see which one is best. Before flashing, I would like to backup the current ROM (with all installed apps and settings), just in case the other kernels are not as good as the current, then i will flash back, please instruct how to backup the current ROM on the unit. Thanks
Originally posted by minhvong99 View PostHi Bob and all. After flashing the unit with a specific kernel and install many apps, but also would like to try other kernels to see which one is best. Before flashing, I would like to backup the current ROM (with all installed apps and settings), just in case the other kernels are not as good as the current, then i will flash back, please instruct how to backup the current ROM on the unit. Thanks
Originally posted by Loser View Posttried to read through all the pages but i got bored. Anyone having reboot/shutdown issues on this like in 1.7?
Originally posted by Pluto View PostHappened in all roms tbh, it is a general issue in my opinion.
007 is screwed up for HULU
I believe either they screw up all the other version or they accidentally unscrewed something in 006c!
Originally posted by Loser View Postoh, i had no shutdown issues in 1.6, but i did on minix images and with 1.7, i didn't run 1.5 for very long but i think i had some restarts on that. Guess i'll reflash 1.6 till it gets sorted or try Lewy's HFW. Minix seems pretty active on their end so no biggie.
003, 004, 005, 006x all with two scenarios, rooted and not-rooted, Finless 1.4/1.5, Lewys Hybrds (1.2.x, 2.0.x), Strauzos, all with different kind of kernels, i have tried literary all of them, excluding the justxbmc and leolas rom, i have found finless always to be the most responsive and performant, but in this painful and informative path, i have had restarts and shutdowns randomly.
Restarts i had mostly from browsing (memory is getting clearer), while shutdowns are a result of heavy lags, quite sure here.
PS, i think Mikael has quite a valid point there, we must do some exact testings to isolate the problem here.
I've spread the idea before to create a list of issues we face in daily use, but i did not get my back there, people seem way more occupied to get accessories work right, it seems to matter a lot whatpeople use it for, i dont have Windows at home anymore ever since i got this device, quite a Desktop Replacement Tool in my opinion.
Originally posted by Matrixlyn View PostI disagree though...006c can runs any Hulu version including the latest version just fine. Not just HULU, other users has reported CBS, CW. What makes this 006c so different and runs these apps so well?? None of the 007 variant can run it...
Originally posted by Finless View PostIt's something to do with Digital Rights Management. RockChip changed something here and MANY other latest TV stick ROMs have this problem. I bet you will see a Hulu update that fixes it later.
There are currently 3193 users online. 1 members and 3192 guests.
