Just so I'm clear my initial objective was to prove the X7 in some configuration would play that high bitrate 1080p content perfectly (otherwise I've made a bad purchase - hopefully not). Objective 2 was then to get XBMC delivering that perfect experience for the convenience of the UI (as I'm familiar with XBMC from my htpc and Rasp Pi etc).
You recommended installing lewy's XBMC (which I'll do tonight, thanks) in answer to Q2, but your answer to Q1 was using MX Player not XBMC. To clarify do you think XBMC won't be able to handle the mkvs or did I misinterpret that?
Thanks in advance.
