And how do I configure it (e.g. pairing ...)
UPDATE - K-R42 - wasser firmware - Kikat Android 4.4.2
Originally posted by Bionicman View Post
And how do I configure it (e.g. pairing ...)RK3288 Devices
- Overview BOX (LINK !)
OK, THX
Originally posted by Bionicman View Post... Tested with CSR (small chineese dongle) and BCM92045NMD Bluetooth 2.0 Module for HP.
RK3288 Devices
Originally posted by no_spam_for_me View Post
And Yes, I mean it works with two different BT modules. Not with both together.
Try the driver and tell me if it works. I am happy to help to set it up.
Originally posted by Bionicman View PostYeah, had to get it from my older HP PC and had to attach a 5V to 3.3V converter to power the module )
Sorry, have no dongle/module... but really interesting in... but maybe (I think so) another one will test it... (and if I know a cheap one will work, I will order it )...RK3288 Devices
Been trying to enable a BT dongle but for the life of me I can't get past the first stage.
Despite mounting system as R/W and then copying the first file using root explorer, the process seems to go well, with no errors, except that the file just doesn't appear in the modules folder.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by bluesmanuk View PostBeen trying to enable a BT dongle but for the life of me I can't get past the first stage.
Despite mounting system as R/W and then copying the first file using root explorer, the process seems to go well, with no errors, except that the file just doesn't appear in the modules folder.RK3288 Devices
Love this latest firmware, it's the first where xbmc 1080p is faultless, well almost. I've noticed on fast moving scenes I get little audio dropouts using pass through. The amp display briefly flashes when it looses signal. Same on optical or HDMI passthrough!. Just wondering if anyone else has seen this?
I'm on a k-r42, old I think, don't exactly remember!
Thanks,
Matt
HDMI and TV-out simultaneous
Hi wasser!
I've got K-R42 TN-BX09_V2.1 (actually 2 of them, but one is OK). I flashed your KK firmware 1.0.3 for old versions of the box (was lewy 3.2 HFW).
Everything is working just great except HDMI and TV-out simultaneous. When HDMI cable is plugged in Box & Monitor (FullHD or TV with full HD) there's no analog TV-out, when HDMI is unplugged I can see analog TV signal. Gone back to lewy firmware, but got same issuse (before upgrade to your FW everything was fine). When I load to CWM - got both signals together.
Is it kernel problem or my hands? ))))
Originally posted by DCrunch View PostBluetooth works! Wow! It's amazing, thank you.RK3288 Devices
Is there a way to set this XBMC as default launcher ?
i have been testing alot, and i want XBMC to startup as default, all the apps i used are also available in XBMC and since im using my Mobile Phone as Remote with the XBMC Remote app it is superb !!!
then i dont have to go back to the android system
SMB Shares work flawless in this XBMC version, everything is setup now like i want it except to start as default launcher
Nevermind, fixed it by installing this app : https://play.google.com/store/apps/d...etHomeLauncherHome Cinema Setup Livingroom:
50" Panasonic Plasma - CS-X806 (s802 1gb/8gb) with Mele F10 on OpenElec 5.0.3 with Kodi - Pioneer Receiver - JBL Surround System - 4TB NAS
Bedroom Media Setup:
32" Philips LCD - KR-42 wasser rom
Originally posted by no_spam_for_me View PostDo you remember my nfs script and the batch? Use the adb commands to do the remount, copy and chmod and so on...
Tried again using ADB but regardless of the fact that /system is mounted as r/w, when I try to push the files, the prompt comes back to say that the destination is read only.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by bluesmanuk View PostNot sure what you are referring to in terms of the nfs script.
BTW, how can you see that /system is in RW?
There are currently 3091 users online. 1 members and 3090 guests.
