I flashed with the new revision should it have been the old?
UPDATE - K-R42 - wasser firmware - Kikat Android 4.4.2
Originally posted by Tommya2004 View PostI flashed with the new revision should it have been the old?
Hi wasser,
It definitely was something wrong with my tired head yesterday when I tried to overclock your kernel.
I had two kernels pulled out from the ROM but by different ways. First kernel was taken by using
dd if=/dev/block... command and second one with wendal software.
It was expected to use wendal output for overclocking, but I wrongly used another one.
So I have tried to redo my experiment today and I managed to obtain working overclocked kernels using d33's script with little changes which were implemeted by me yesterday.
So what I have now with kernel_cpu1704h_gpu798h_ddr800 is here
and several significant lines from dmesg too
Code:<5>[ 0.000000] Linux version 3.0.36+ ([email protected]) (gcc version 4.7 (GCC) ) #5 SMP PREEMPT Wed Jun 4 14:11:53 CEST 2014 . . <4>[ 0.914323] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 6000 <4>[ 0.914432] adjust table freq=[COLOR=#ff0000]1704000[/COLOR] KHz, index=1375000 mV to index=1350000 mV <4>[ 0.914499] efuse_version_val: efuse version = 51 <4>[ 0.914541] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 6000 <4>[ 0.914603] adjust table freq=[COLOR=#ff0000]594000[/COLOR] KHz, index=1375000 mV to index=1350000 mV . . <6>[ 2.111325] ddrfreq: normal 792MHz video 0MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 0MHz reboot 220MHz <6>[ 2.112201] ddrfreq: change freq to [COLOR=#ff0000]792[/COLOR] MHz when normal . . <4>[ 4.679012] Mali: mali freq table :Mali: 297,Mali: [COLOR=#ff0000]594[/COLOR],Mali: [COLOR=#ff0000]594[/COLOR],Mali:
I don't know why it is happening, but mali_dvfs always shows me:
297,594,594
It doesn't matter which kernel I use.
What do you think about it?
Kind regardsCS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
ap6210
Do you have support wifi ap6210 ????
Originally posted by wasser View Postversion 1.0.3
- K-R42 new and old revision support
- perfect 1080p fullhd video streaming
- multiuser support
- busybox up to date
- google apps up to date
- screen rotation support
- reboot/sleep/bootloader mode dialog
- add TVOUT support
- full support stock ir remote
- lock screen support
- preload wasser xbmc-1.1 based on gotham 13.1 stable release
- passthrough support in wasser xbmc
- add setting for Accessibility
- add setting for sleep, daydream and wallpaper
- add support for Mouse Wheel Zoom Settings
- add support for no wakup on mouse movement, enable it by default
- add manual hide system bar, you can wipe from bottom/top of screen to show it again
- add setting for Alarm/Notifications volume
- add support hls streaming
- fixed red frame issue in chrome browser
- added option to disable the hardware keyboard (add ro.hardkeyboard.support=false to
/system/build.prop to disable hardware keyboard )
- several fixes which i don't remember
firmware for new revision: wasser-firmware-kikat-kr42-new-1.0.3.zip
firmware for old revision: wasser-firmware-kikat-kr42-old-1.0.3.zip
please use RKBatchTool to flash the new firmware
version 0.92
- Ugoos Ut1, k-r42, t-r42 and MinixX7 (all revision support, please select the correct kernel)
- Kikat 4.4.2
- wifi support
- ethernet support
- init.d support
- rooted
- ntfs, nfs, iso, cifs filesystem support
- preinstall es file manager, reboot
- cwm recovery
- 1080p24hz, 1080p30hz, 1366x768p60hz support
Link download:
version 0.91
- k-r42 old revision support
- k-r42 new revision support ( you have to flash this kernel after firmware flash)
- based on android 4.4 (kikat)
- wifi support
- ethernet support
- init.d support
- rooted
- new kernel, fix tv-out and hdmi bugs
- cwm recovery
- fixed high CPU load from rk_rtl_gc process
Link download:
version 0.90
- wifi support
- ethernet support
- init.d support
- rooted
Link download:
please post your feedbacks, it's very important!
Originally posted by digger View PostIt was expected to use wendal output for overclocking ...
Would you like to attach the modified script?
BTW: what score without OC?RK3288 Devices
- Overview BOX (LINK !)
Here is modified script
overclockomatic_kk1.zipCS918II/16GB(HTC-031-V1.0 board)
Originally posted by griffdaddy View PostInstalled this last night and everything seems to run really smoothly. The only problem is that pass through still doesn't work in xbmc. I have it enabled in Android settings and when I turn it on in xbmc it force closes. Anyone got any ideas? My k-r42 is connected to an onkyo amp
Settings->System->Audio ouput->Enable passthrough
You have to set Setting level (Settings->system) to expert and set Outpur configuratiion to Best Match to get this option
There are currently 2165 users online. 6 members and 2159 guests.
