version 1.0.4
- included all features/fixes from previous release
- added localation setting
- 8gb in one partition
- fixed a bug in hardware keyboard setting
- google apps updated
- several fixes which i don't remember
- wasser xbmc 1.2
- improved hdmi driver, system stability
firmware for new revision: http://www.freak-tab.de/wasser/wasse...-new-1.0.4.zip
firmware for old revision: http://www.freak-tab.de/wasser/wasse...-old-1.0.4.zip
please use RKBatchTool to flash the new firmware
version 1.0.3
- K-R42 new and old revision support
- perfect 1080p fullhd video streaming
- multiuser support
- busybox up to date
- google apps up to date
- screen rotation support
- reboot/sleep/bootloader mode dialog
- add TVOUT support
- full support stock ir remote
- lock screen support
- preload wasser xbmc-1.1 based on gotham 13.1 stable release
- passthrough support in wasser xbmc
- add setting for Accessibility
- add setting for sleep, daydream and wallpaper
- add support for Mouse Wheel Zoom Settings
- add support for no wakup on mouse movement, enable it by default
- add manual hide system bar, you can wipe from bottom/top of screen to show it again
- add setting for Alarm/Notifications volume
- add support hls streaming
- fixed red frame issue in chrome browser
- added option to disable the hardware keyboard (add ro.hardkeyboard.support=false to
/system/build.prop to disable hardware keyboard )
firmware for new revision: wasser-firmware-kikat-kr42-new-1.0.3.zip
firmware for old revision: wasser-firmware-kikat-kr42-old-1.0.3.zip
wasser xbmc: http://www.freak-tab.de/wasser/wasser-xbmc-v1.2.apk
tool to set the static MAC address: rk3188-UpgradeDll-tool-v1.26.zip
version 0.92
- Ugoos Ut1, k-r42, t-r42 and MinixX7 (all revision support, please select the correct kernel)
- Kikat 4.4.2
- wifi support
- ethernet support
- init.d support
- rooted
- ntfs, nfs, iso, cifs filesystem support
- preinstall es file manager, reboot
- cwm recovery
- 1080p24hz, 1080p30hz, 1366x768p60hz support
Link download:
version 0.91
- k-r42 old revision support
- k-r42 new revision support ( you have to flash this kernel after firmware flash)
- based on android 4.4 (kikat)
- wifi support
- ethernet support
- init.d support
- rooted
- new kernel, fix tv-out and hdmi bugs
- cwm recovery
- fixed high CPU load from rk_rtl_gc process
Link download:
version 0.90
- wifi support
- ethernet support
- init.d support
- rooted
Link download:
please post your feedbacks, it's very important!
- wasser xbmc 1.2
version 1.0.3
- multiuser support
- add TVOUT support
version 0.92
- Kikat 4.4.2
- wifi support
- ethernet support
- init.d support
- rooted
- cwm recovery
Link download:
version 0.91
- wifi support
- ethernet support
- init.d support
- rooted
- cwm recovery
Link download:
version 0.90
- wifi support
- ethernet support
- init.d support
- rooted
Link download:
