UPDATE - K-R42 - wasser firmware - Kikat Android 4.4.2
Laggy mouse cursor is probably associated with high CPU load from rk_rtl_gc process. But there is possibility to make system work almost smoothly and very fast. Go to Settings->Developer option and disable all animation (animation scale 1x -> no animation) and also change Dalvic to ART. First boot after that will take "half your life" but after that system will be born almost anew.Last edited by Gormar; 12-12-2013, 12:24.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Do not be hasty. Right now I wouldn't recommend this firmware because one process "eats" one core of the CPU which causes quite much heat.Last edited by Gormar; 12-12-2013, 12:25.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostDo not be hasty. Right now I wouldn't recommend this firmware because one process "eats" one core of the CPU which causes quite much heat.
Originally posted by bluesoho View PostDo yo have plan to release to T-R42 ROM? or is this ROM work on T-R42?
I really want to use Kikat on my T-R42!
Originally posted by wasser View Postthis problem is fixed in 0.91 firmware.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostWhen it will be available to us? This would be greate Cristmass gift .
Originally posted by wasser View Postno wory, it' s scheduled before christmas ;-)
Franckfor windows8.1 drivers fix follow this.
Jesurun v2.1 old rev with wasser firmware 1.2.5
K-R42 v2.1 new rev with wasser firmware 1.2.5
Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
Minix neo s8s with stock firmware
Plex streamer with external MX player
TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
Merry Christmas to you too . I will install this revision right now but will not bother you with any question/request during Holidays .RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
@wasser.
In the 0.91 version analog audio output doesn't work.
Also big drawback is that emulated storage is placed on data partition. Internal or external SD card isn't used at all.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
2- will be fixed in next release
There are currently 2678 users online. 3 members and 2675 guests.
