Franck.
UPDATE - K-R42 - wasser firmware - Kikat Android 4.4.2
Originally posted by newhousik View Post
Franck.for windows8.1 drivers fix follow this.
Jesurun v2.1 old rev with wasser firmware 1.2.5
K-R42 v2.1 new rev with wasser firmware 1.2.5
Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
Minix neo s8s with stock firmware
Plex streamer with external MX player
TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
Originally posted by wasser View Post1- does the analog audio output work in 0.90?
There must be some problem with default sound routing.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
On Ut1 not works nice Version 0.91
-screen size was not correct and could not find where adjust it
-back button did not work with Air mouse
-display rotates automatically even if it turns off in some apps
-Audio only works on Optikal no Hdmi
-Keyboard will not open until after hardware deactivating, after reboot is setting off and needs to be adjusted
- The Speed of via the card are just about 10% of my power.
With the original software release on Dec I have full bandwidth for disposal.
I hope this bug can be fixed then it is a great update
svemo
svemo
- hardware keyboard is setting by default. You can disable it if you wanr to have virtual keybaord
- what do you mean with "The Speed of via the card are just about 10% of my power."?
Originally posted by wasser View Post- screen size/rotation/back button audo should be fixed in 4.4.2
Hi Wasser,
i Have DSL 50000 with the Original Software ist my Connection Speed 41000 with the kitkat 4.4 and the 1.24 from you i have only max 8000 .
I testet some Firmeware also Riley Rom but there are the Same Problem..
I like your kitkat 4.4 but with the slow Connection date itself runs without hanging youtube and other Apps how need the internet Connection.
Sorry for my bad English, i am only speak german.
svemo
svemo
Originally posted by Svemo View PostHi i test it offen with LAN cabel other Router and and and.
Only with original firmeware it is OK
When we geht the 4.4.2?
Svemo
great work wasser. thx for it.
could you tell me the default cpu clock of the new rev kernel? is it still limited to 1400 mhz or the default 1600 mhz for the rev 2.1 k-r42?
still looking for a kernel with default cpu clock and ethernet working fine on rev 2.1 k-r42----------------------------------
K-R42 - Rev 2.1 - 31.05.2013
Firmware Wasser 1.2.5 new rev kernel
Originally posted by wasser View Postthis kernel doesn't have cpu lock, it should work
I'll try tonite on a k-r42 new revision.
Franckfor windows8.1 drivers fix follow this.
Originally posted by Svemo View PostOptical Sound's does not work on UT1
No boot screen on HDMI, no Bootlogo
No Screen on CMW
Svemo
it could be optical sounds doesn't work, 0.92 firmware bases on 4.4.2 which still has some issues,
so don't expect that everything works!
i have tested ut1 and it works fine for me, i see the boot screen! It's strange it's not working for you. please try to connect to fullHD TV
There are currently 3172 users online. 2 members and 3170 guests.
