Yellow - video, red - right and white left audio.
UPDATE - K-R42 - wasser firmware - Kikat Android 4.4.2
Originally posted by pavlik View PostI'va already found a best solution to get more (unlimited) space for our boxes (especially for big games like Bully, GTA games).
Note: Root and fast flash drive / sd card with unique label is needed.
1. Install Xposed framework from: http://repo.xposed.info/module/de.ro...osed.installer
2. Install XInternalSD module from: http://repo.xposed.info/module/com.pyler.xinternalsd
3. Open Xposed and install framework (no need to restart right now).
4. Go to modules, activate XInternalSD by click in radio button
5. Click on module name and configure it (activate and edit path to extrenal SD Card or USB flash, add all apps or configure own app list for use external device).
6. Move data / obb / emu config folders to Your new path.
7. Restart device.
I've using 64GB 3.0 USB Flash Drive and games working faster than from internal storage because of not one but two drives.
Originally posted by Bionicman View PostUSB Bluetooth Dongle support
Hi all,
I was working on adding USB Blueooth dongle support to the K-R42 device.
It seems that I succeeded (at least it works for me) and want to share the solution. Please see attached file. The instructions are included in the Readme.txt file.
[ATTACH]6767[/ATTACH]
USE IT AT YOUR OWN RISK!!!
PS: This works only with KitKat kernels!
PPS: This is ONLY for devices WITHOUT BT!
-Bionicman
This rom is good enough. But I'm looking for a better one. Anyone ever tried this http://chinagadgetsreviews.com/downl...-tv-boxes.html which is newer. The rom is here https://mega.nz/#!NgBEmRyb!8KXHbMEI8...eJFKz0A0wi3OQs I think it's smoother but I have never tried oc the kernel.
Originally posted by foulbird View Post
K-r42 is rather old for current 3D games due to hardware performance. But it's still good to keep now to save money for a much better one. With wasser firmware, I still can enjoy lots of functions, like kodi movie, action heavy games (with wireless gamepad). Many good games still run smoothly on k-r42 like dead effect 2, asphalt 8, Modern combat etc. If you find some games laggy, use gltools xda version for free.
Originally posted by pavlik View PostI've already made AV modification in my box by removing 4pin jack and solder standard av 3 x chinch:
With long cables (3m+ for projector) there was a drop of quality with AV. I sold this box and bought a great X92 (3/32) for almost 1:1 of price: http://freaktab.com/forum/tv-player-...l-wifi-gig-lanX92 3/32 Android TV Box with Ugoos AM3 Firmware
Originally posted by wasser View Postversion 1.0.4
- included all features/fixes from previous release
- added localation setting
- 8gb in one partition
- fixed a bug in hardware keyboard setting
- google apps updated
- several fixes which i don't remember
- wasser xbmc 1.2
- improved hdmi driver, system stability
firmware for new revision: http://www.freak-tab.de/wasser/wasse...-new-1.0.4.zip
firmware for old revision: http://www.freak-tab.de/wasser/wasse...-old-1.0.4.zip
please use RKBatchTool to flash the new firmware
version 1.0.3
- K-R42 new and old revision support
- perfect 1080p fullhd video streaming
- multiuser support
- busybox up to date
- google apps up to date
- screen rotation support
- reboot/sleep/bootloader mode dialog
- add TVOUT support
- full support stock ir remote
- lock screen support
- preload wasser xbmc-1.1 based on gotham 13.1 stable release
- passthrough support in wasser xbmc
- add setting for Accessibility
- add setting for sleep, daydream and wallpaper
- add support for Mouse Wheel Zoom Settings
- add support for no wakup on mouse movement, enable it by default
- add manual hide system bar, you can wipe from bottom/top of screen to show it again
- add setting for Alarm/Notifications volume
- add support hls streaming
- fixed red frame issue in chrome browser
- added option to disable the hardware keyboard (add ro.hardkeyboard.support=false to
/system/build.prop to disable hardware keyboard )
firmware for new revision: wasser-firmware-kikat-kr42-new-1.0.3.zip
firmware for old revision: wasser-firmware-kikat-kr42-old-1.0.3.zip
wasser xbmc: http://www.freak-tab.de/wasser/wasser-xbmc-v1.2.apk
tool to set the static MAC address: rk3188-UpgradeDll-tool-v1.26.zip
version 0.92
- Ugoos Ut1, k-r42, t-r42 and MinixX7 (all revision support, please select the correct kernel)
- Kikat 4.4.2
- wifi support
- ethernet support
- init.d support
- rooted
- ntfs, nfs, iso, cifs filesystem support
- preinstall es file manager, reboot
- cwm recovery
- 1080p24hz, 1080p30hz, 1366x768p60hz support
Link download:
version 0.91
- k-r42 old revision support
- k-r42 new revision support ( you have to flash this kernel after firmware flash)
- based on android 4.4 (kikat)
- wifi support
- ethernet support
- init.d support
- rooted
- new kernel, fix tv-out and hdmi bugs
- cwm recovery
- fixed high CPU load from rk_rtl_gc process
Link download:
version 0.90
- wifi support
- ethernet support
- init.d support
- rooted
Link download:
please post your feedbacks, it's very important!
Anybody has the problem of downloading this firmware? 1.04 new?
either I save it as or click and save as,to no avail.
I don't see any android 5.1.1 for RK3188,no SDK from manufacturer?
thanks.
There are currently 2428 users online. 6 members and 2422 guests.
