UPDATE - K-R42 - wasser firmware - Kikat Android 4.4.2
Originally posted by fossxplorer View PostHmm, ok. Also, the seller sent me the following screenshot.
It shows only 4GB storage, while it's sold as 8GB.
Is it the case with all the other versions of CS918?
[ATTACH=CONFIG]10269[/ATTACH]
it is 8gb. just its split across Nand storage and Internal storage.
i dont understand why devs keep splitting the internal storage across 2 partitions. it serves no benefit whatsoever
K-R42 video problem
Originally posted by wasser View Postversion 1.0.4Wasser, this maybe this have nothing to do with your ROM, but let me ask to check it out....
I had worked with your ROM for a K-R42 since almost a year, with excelent results (up to 1.03 version)...
This weekend I decided to update my Android box with 1.04, mostly because storage issues (i wanted to install a really big app, and particioning in 1.03 was restraining me).
After sucessfully installing 1.04, I noticed that there was no option for 1080p in display config (but my test screen was 720p, so I did not gave it too much importance).
After moving this box to it former TV (1080p) it did not start at all (display at least).
Going back to my lab setup, it did work well, but then it was when a noticed that if I unpluged USB cable to my laptop, the box will shutdown, and it only will restart if I coneccted it back.....
...dont really think this is a firmare problem, but no harm if I ask.... any help if welcome....
I want the same
Originally posted by pes1313 View PostHi all ! In wasser 1.0.4 firmware in setting , all 8gb memory in one partition,I can be made as before ? : for sd card a separate section is not emulation ,
I need to change the micro sd card with sd card ,i want to sd card 32 gb ?
I can flash the parameter file ? with settings: for applications 4GB and for sd card 2 gb ?
First of all, thanks for all ur support to the comunity.
Im using Wasser 1.0.4, and i want to use a 32GB external sd card, but i cannot change sd card with external sd card.
Is there a workaround to this issue?
Thanks in advance
If I understand it correctly you want to ""expand"" the internal eMMC/NAND with the SD?
=> http://www.freaktab.com/showthread.p...l=1#post219870RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostIf I understand it correctly you want to ""expand"" the internal eMMC/NAND with the SD?
, because memory 1.0.4 (4.4) goes one partition , I can not change the mount pointLast edited by pes1313; 03-05-2015, 19:23.k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
rom 1.0.4 (kitkat) old revision Wasser
hmmmm, I never tried it, but maybe because the 4.4.2 at rk3188 isn't a real 4.4.2 (it's only a modified 4.2)...RK3288 Devices
That's rather strange. Do you have Vendor_0e8f_Product_0003.kl file in /system/usr/keylayout/ directory?
Second question. Where did you test LT and RT buttons? They should report as BUTTON_L2 and BUTTON_R2 to Android joypad applications.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostDo you have Vendor_0e8f_Product_0003.kl file in /system/usr/keylayout/ directory?
Originally posted by Gormar View PostThey should report as BUTTON_L2 and BUTTON_R2 to Android joypad applications.X92 3/32 Android TV Box with Ugoos AM3 Firmware
I'm not exactly shure if that USB device name (Vendor_0e8f_Product_0003) will be usefull for you because you use Bluetooth dongle but I can send you this config file.
Vendor_0e8f_Product_0003.txt
Probably right now you gamepad is configured as Generic.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by no_spam_for_me View Posthmmmm, I never tried it, but maybe because the 4.4.2 at rk3188 isn't a real 4.4.2 (it's only a modified 4.2)...k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
Originally posted by Gormar View PostI'm not exactly shure if that USB device name (Vendor_0e8f_Product_0003) will be usefull for you because you use Bluetooth dongle but I can send you this config file..
Are you pulling my leg or something? This is proper thread about that TV Box.
That CS918 device with PCB: CH001 (1329) TN-BX09_V2.1 2013/05/31 = old version.
1329 is a year and week of manufacturing = 29th week of 2013.
Check here.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
There are currently 2423 users online. 4 members and 2419 guests.
