http://freaktab.com/forum/tv-player-...to-ext-sd-fail
UPDATE - K-R42 - wasser firmware - Kikat Android 4.4.2
Originally posted by axinak View Post
http://freaktab.com/forum/tv-player-...to-ext-sd-failRK3288 Devices
- Overview BOX (LINK !)
Hi all ! has anyone tried to flash the firmware from minix x7 version 2.0.2 from wasser ? in the subject for minix wasser wrote that this rom uses the new sdk , and d33 wrote in his thread all new kernels only for new firmware , as I understand
p.s. it would be cool if Wasser adapted its rom from mininx x7 for k-r 42
P.s. 2 Please tell somebody what the latest kernel is for our k-r42 ?
Last edited by pes1313; 05-05-2015, 01:03.k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
rom 1.0.4 (kitkat) old revision Wasser
Originally posted by pes1313 View PostHi all ! has anyone tried to flash the firmware from minix x7 version 2.0.2 from wasser ?
Maybe there is a chance to appeal to Wasser and he will prepare similar firmware for this device .
For me 1080p Youtube application is a must but such good firmware will make me regret that I bought new device with RK3288 SoC and I will use older one more often.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostI think that without proper kernel for K-R42 new firmware would not work.
P.s. I ask him and he say : dont planed release..Last edited by pes1313; 05-09-2015, 18:59.k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
Originally posted by no_spam_for_me View PostHi all,
I was working on adding USB Blueooth dongle support to the K-R42 device.
It seems that I succeeded (at least it works for me) and want to share the solution.
Originally posted by mariosm1cy View PostHi guys, quick question. What happens if i flash new revision firmware on old revision hardware?
But if you have even newer K-R42 BOX (bought after middle of 2014) you might be in trouble.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostIf you realy have got old/new revision K-R42 Android TV Box then when you flash different kernel version it will only disable LAN and eventually Bluetooth. Nothing major like bricking your device and you will only need to reflash kernel with proper/other version.
If only eth not working, then maybe old rev could help...RK3288 Devices
I've already tested bluetooth usb dongle (based on csr chipset) with kernel from 1.0.3 and it working! Thanks Bionicman
Drivers posted some time ago in this topic are needed:
http://freaktab.com/forum/tv-player-...d-4-4-2/page20
Tested also rounded one and bt won't turn on.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoX92 3/32 Android TV Box with Ugoos AM3 Firmware
I just wanted to tell that I kind of solved the problem with the Logitech K480 by using another USB bluetooth dongle (LINK). The adapter is based on a different chipset (Broadcom BCM20702 instead of CSR8510 from my old Dongle). So the problem is neither the bluetooth stack nor the keyboard but rather the integrated driver. With the new dongle the pairing works and it shows "Broadcom HID" in the input settings. With the old dongle the pairing is not possible.
There are currently 2419 users online. 4 members and 2415 guests.
