UPDATE - K-R42 - wasser firmware - Kikat Android 4.4.2
Maybe it's because of KK (isn't Lewy's 1.20 JB?) ...RK3288 Devices
- Overview BOX (LINK !)
Re: UPDATE - K-R42 - wasser firmware - Kikat Android 4.4.2
Originally posted by no_spam_for_me View PostMaybe it's because of KK (isn't Lewy's 1.20 JB?) ...
No, I've just tried again on my nexus 5 with Cyanogenmod kitkat and it plays perfectly...
Sent from my Nexus 5 using Tapatalk_________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
AW: UPDATE - K-R42 - wasser firmware - Kikat Android 4.4.2
What is with mirroring, does it work.?
Cyanogenmod 11 has this feature now?
Gesendet von meinem GT-I9305 mit Tapatalk
Sent from my Nexus 5 using TapatalkRK3288 Devices
I can either play off my nexus 5 phone or I can cast the nexus5 screen to my chromecast dongle... Works fine too...
Originally posted by fergietime View PostWhat are the chances of getting a tweaked version of this for the CYX_CS918 V2_3? I'd try it myself if I knew how or had the time to build up the knowledge. I've done a bit of android development but no idea where to start when it comes to these android builds.
Maybe it will work with the KK which wasser build, if not, you have to look if you get the SDK and build your own KK...
good luckRK3288 Devices
Originally posted by no_spam_for_me View PostHave you Linux knowledge? Have you kernel-build knowledge? Have you hardware knowledge? If yes, you can search for the existing basic kernel source and begin to build up a kernel source like wasser's with the need parts for your hw...
good luck
Originally posted by AIvaBY View PostDear Wasser! Can you fix problem with hotspot wi-fi? It is very necessary for me.
if you are plugged in to a wall to power your device, surely you can plug in another device to provide wifi access?
it seems like something that very few other users would use... maybe I am wrong, but what stops you from buying a cheap device to provide wifi?
(wasser's time is also worth something!
cheers
Mark._________________________________________
Originally posted by fredphoesh View Postwifi hotspots are mostly functions for portable devices so you can give wifi access from a phone.
cheers
Mark.
Originally posted by AIvaBY View PostAt my home I have a toast walls and the main modem signal is not available in one of the rooms. Access point on the device allow me to distribute the Internet in that room. In addition, the device supports the organization of access point, why limit its functionality?
I don't know that the function has been "limited", but wifi access points are very cheap, this is an old device, and wasser has lots of other things to do...
I shouldnt be speaking for him, but I imagine you will have more success by using a different device to provide wifi... I use one that plugs into my AC wall socket and it works very well.
Mark_________________________________________
Mark
Originally posted by AIvaBY View PostI understand everything and I realize. But to buy another device and take one more AC wall socket would not want to. If Wasser did not consider it necessary to fix this defect, so be it. Thank you and sorry for my bad eanglish
This is the kind of thing...
http://www.amazon.co.uk/TP-Link-TL-W...294650&sr=1-10
There are currently 2811 users online. 5 members and 2806 guests.
