UPDATE - K-R42 - wasser firmware - Kikat Android 4.4.2
Originally posted by okhulto View PostIs there a bluetooth adapter compatible with K-R42?
Hi all,
I was working on adding USB Blueooth dongle support to the K-R42 device.
It seems that I succeeded (at least it works for me) and want to share the solution. Please see attached file. The instructions are included in the Readme.txt file.
USB_BT_Drv.zip
USE IT AT YOUR OWN RISK!!!
PS: This works only with KitKat kernels!
PPS: This is ONLY for devices WITHOUT BT!
-Bionicman
THX
Does it work with every BT-Dongle and BT-Version?
Or do I need a special one?
This is generic driver, so it must work with many devices.
Tested with CSR (small chineese dongle) and BCM92045NMD Bluetooth 2.0 Module for HP.
PS:
And how do I configure it (e.g. pairing ...)
You do it as you would normally do via Android GUI.
Really something like this
Yeah, had to get it from my older HP PC and had to attach a 5V to 3.3V converter to power the module )
Try the driver and tell me if it works. I am happy to help to set it up.
Sorry, have no dongle/module... but really interesting in... but maybe (I think so) another one will test it... (and if I know a cheap one will work, I will order it )...
I have a CSR 4.0 and for me it´s working, here the extract from dmesg and 2 screenshots.RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View Posthttp://www.freaktab.com/showthread.p...l=1#post195072
Hi all,
USB_BT_Drv.zip
-Bionicman
THX
PS:
I thank you test here.
Cee604, even with 1080p kernel you can set HDMI output to 720p mode and displayed screen will be scaled down to 1280x720p resolution. In your case it is most desirable to run 720p kernel. Wasser firmware supply that and you can reflash them from within the system. Default is 1080p kernel.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
neither ... nor
It's a board which I bet will never work with this fw...
I think you will brick your device if you flash this fw!RK3288 Devices
Hi all ! In wasser 1.0.4 firmware in setting , all 8gb memory in one partition,I can be made as before ? : for sd card a separate section is not emulation ,
I need to change the micro sd card with sd card ,i want to sd card 32 gb ?
I can flash the parameter file ? with settings: for applications 4GB and for sd card 2 gb ?Last edited by pes1313; 01-20-2015, 10:08.k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
rom 1.0.4 (kitkat) old revision Wasser
There are at least two version of AC8350. Thanks God that you have taken PCB pictures.
It is almost certainly identical to T-R42 old revision. Therefor Wasser's 2.0.4-old ROM should work fine.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Without any information about the pcb, NO WAY to answer...RK3288 Devices
There are currently 2376 users online. 6 members and 2370 guests.
