Sent from my Galaxy Nexus using Tapatalk
UPDATE - K-R42 - wasser firmware - Kikat Android 4.4.2
Originally posted by gjurriens View PostWhow... how nice to be able to run KitKat on our devices.
I'll test as soon as I have the time.
It would be great if this new rom had Bluetooth Low Energy API support that was introduced in 4.3 ...
Originally posted by georget View PostDoes installing this rom really mean we are running KitKat on our K-R42 boxes??? The OS will still be 4.2.2 right?
http://developer.android.com/guide/t...etooth-le.html
I installed it on my box (ENY Techno) and after boot, I can select the language but once click, it refuse to go further. Seems to be freezed. After reboot, it returns to the language selctection.
My problem is now when connecting the box to my PC, Rock BatchTOol can't be used. The driver loaded is Nexus by default... can you tell me how to change this. I tried to desingtall Nexus driver, but when pluged , it willinstall nexus driver again.
thanks
OK, about the language selection, it was because of my mouse remote air. I used a regular usb mouse, and I've been able to select language and finish configuration. Except wifi that doesn't work.
I still want to load a new rom, but driver in W7 PC still load Nexus driver. If you have any idea, I'll be happy to use again my RockChip Batch tool
@benico
Originally posted by benico View PostI installed it on my box (ENY Techno) and after boot, I can select the language but once click, it refuse to go further. Seems to be freezed. After reboot, it returns to the language selctection.
thanks
Wifi works when the lan cable is disconnected.
When the box is connected to the PC it is recognized as what it is declared, when the reset button is pressed, the box is recognized as a Rockchip device.
salsa
salsa
I read a lot of things about wifi pb, and it seems to be related to this K-R42 vs T-R42 (means with or without bluetooth). I assume mine have bluetooth as writen on the site of the box I bought (http://www.aliexpress.com/store/prod...001649535.html)
As I'm new in this univers, I'm confused between ROM, Kernel, image,...maybe if someone can tell where learning such information, I'll be happy
I think it will be better for me starting by this.
Thanks!
Test result Kitkat 4.4 NEW kernel
K-R42 2.1 New kernel.
antutu +15000 1080x1848 flipped 90 deg left. a bit slow
And the screen stays flipped after Antutu is closed ??
Wifi = ok
Ethernet = OK
new mac after reboot thoug.
youtube - working
Netflix Denmark- working
JustXBMCv4.apk not working, in fact no versions of XBMC work, tested 4 diff versions also the official version.
IR remote - Mouse function not working
Gyro mouse - BACK = select.
NO HDMI mode
No scaling, and scale is of, to large by 10 % approc.
Full!screen app, replaces hide menu i guess, and it works.
Thanks for the good work :-)
If you don't want flipped screen then disable screen rotation in system setting.
Nice work Wasser. Today I only had one hot reboot. In comparison to HFW 2.0.4 it is quite good progress for me.
Strange thing that "Inverted rendering" in system web browser doesn't work.
Besides only one luncher screen is rather to much constrain. I didn't try to install other only because I changed default DPI to 160 from 240.
One more thing. Only first connected USB drive is recognised and it have to be vfat formated. My other pendrive with NTFS partition I must mount from Shell. This cannot be easly solved by users because after Android 4.3 there is no /etc/vold.fstab and all storage option are managed in /fstab.rk30board.bootmode.unknown.
And now realy last thing: emulated storage is located in /data/ partition which has only 2GB. Internal_SD isn't used by any installed applicationLast edited by Gormar; 12-08-2013, 20:35.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
KiTKAT TEST
I have a k-r42 Board TN-BX09_V.2.1 2013/05/31 and I was running rom 1.2.3 old revision.
I flashed The 4.4 Kitkat. These are the results:
No Etherenet
No Keyboard
Can not install any apk. from unknown sources (it's checked off in the settings-but, it seems does not to get to be registered- even though it stays as checked off! Weird)
Other than that everything else seems just fine...
Any ideas/suggestions?
Originally posted by scorpio2013 View PostI have a k-r42 Board TN-BX09_V.2.1 2013/05/31 and I was running rom 1.2.3 old revision.
No Etherenet
No Keyboard
Can not install any apk. from unknown sources.
No keyboard. Propably you didn't configure keyboard layout and system doesn't use any default.
I have one APK from unknown sources installed without problem. Dunno what happend with your BOX.
This K-R42 Android KitKat version is rather hard to use especially because one "rouge" process (rk_ftl_gc) is useing one core at full power. My BOX is hot like after many hour of gamming .RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostNo Ethernet but WiFi works? Try disabling it and/or restart router because ever changing MAC address might have "exhausted" its DHCP IP pool.
rk_ftl_gc
Originally posted by wasser View Postit's a bug in the 4.4 firmware, it seems this process comes from new rk30xxnand binary which caues this issue.
This rk_ftl_gc process should be only responsible for NAND garbage collecting but it seems that from some reason it goes south.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostThanks for info. This bug occures only on K-R42 devices or in Minix X7 also?
There are currently 2589 users online. 5 members and 2584 guests.
