Claus
UPDATE - K-R42 - wasser firmware - Kikat Android 4.4.2
OK - Now Sound is gone
Originally posted by tresman View PostHow do you enable that ?
Claus
SO what to do ??
What happens if I flash some of the other kernels (for this I have used
"kernel-k-r42-new" What would happen if I use the "old.." kernel or the ut1 kernel ?
Will all my settings and apps then be lost - or are they saved somewhere else than in the kernel. ??
Apart from the sound problem (and - must admit - some stopping/crashing of the Netflix app)
this firmware by Wasser is very good.
BTW: I noticed that there is no selection of sound devices in the settings.
I hope some of you outthere have found a solution..
Claus
TN-BX09_V2.1 1335 I have the same box
Originally posted by Moszad View PostK-R42 2.1 New kernel.
antutu +15000 1080x1848 flipped 90 deg left. a bit slow
And the screen stays flipped after Antutu is closed ??
Wifi = ok
Ethernet = OK
new mac after reboot thoug.
youtube - working
Netflix Denmark- working
JustXBMCv4.apk not working, in fact no versions of XBMC work, tested 4 diff versions also the official version.
IR remote - Mouse function not working
Gyro mouse - BACK = select.
NO HDMI mode
No scaling, and scale is of, to large by 10 % approc.
Full!screen app, replaces hide menu i guess, and it works.
Thanks for the good work :-)
I have the exact same box with a Mele F10pro remote.
I have also flashed the kitkat 0,92 by wasser - works great but after a reboot theres no sound.
I initially thougt it was the "reboot app" - but its not !
I can se that the sound drivers somehow are missing and the sound setting are from zero sound to full sound (no inbetweens)
Are you having problems with sound - and if, do you have a solution ?
Claus
Sry can't help - No K-r42 box currently.
Claus
Update - I have changed firmware to Lewy 2.0.4 with wasser kernel
Originally posted by tresman View PostOk - I found out that the "no sound" problem has nothing to do with the reboot app thats preinstalled in the FW - Suddenly theres no sound at all ......
SO what to do ??
Claus
SO therefore I have changed to Lewy 2.0.4 with wasser kernel "kernel_1080p-k_r42-revision_2.1-111113"
And here is my initial thougts:
Ethernet + wifi works
Sound works - and volume control too
Software keyboard works on default
HDMI works - but netflix is lagging (shaky picture, stutter) no matter what HDMI resolution I choose.
I have also found out that the general resolution is not so good compared to the kitkat 0.92 (and thats no matter what HDMI resolution I choose) - in general the picture is somewhat grainier - also in hightest resolution (1920x1080p) - as the chosen resolution was'nt the actuel resolution ?
There are some reboots in the middle of netflix - but the are seldom
Antutu is about 17000 - so its not speed that seeems to be the problemmaker.
The power off/reboot switch is GOOD - but the reboot option doesnt function, it hangs in software when trying to reboot.
Please give me your comments - btw. my board is a TN-BX09-V2.1 (datecode 1335) - aka. new revision.
NEW update: due to the stutter thing in netflix I tried to change the lewy build to 3.2 beta and the kernel to this:
kernel-k_r42_new_revision_cpu1800h_ddr800_1080p_gpu600h.i mg
And it works a little better - still some stuttering but the picture quality is way better, not so grainy.
Now I just need the stutter to go away........
ClausLast edited by tresman; 02-16-2014, 21:35.
My 3 different firmware flashings - and the status
Originally posted by tresman View PostI have decided to change firmware - due to the fact that I cant get sound to work anymore (other than reflash everything again)
EDIT to the above: picture quality and lagging is NOT better, just in the beginning, after about 15min - 30min it gets considerably worse - and it cant be fixed by changing resolution !
Claus
I have tried 3 different Firmware flashings - and here are a very brief summary of the results:
The kitkat 0.92 by wasser
- Only sound missing after reboot is a serious problem, everything else very good.
(and I cant get the sound back, no matter what I do)
SO problem is: lack of prober sound devices/driver
The Lewy 2.04 and 3.2 with two different kernels by Wasser (had to use the kernels by wasser in order to get ethernet working)
- Video resolution and lagging is a real problem - otherwise everything is very good
SO problem is: lack of prober video drivers, resulting in a lot of stutter/lagging
Final conclusion
And there I hope that you two gentlemen Lewy and wasser can work something out.......
Regards, claus
Guest
config.cfg:Code:CFG Ü řv 8 8Loader ń ż@ň ›bývÜL‡ţ˙[B]..\rockdev\RK3188Loader(L)_V1.24.bin [/B] Ěň ‡»÷v2¦ń Hň śń \ň `ň ›bývDxC‡ţ˙˙˙ň çÄřvň ň Í«şÜň »÷vň E Ś+ ň ÍřvŘývţĹřvPň Ľ»÷v‡»÷v„1¦ń Ěň ň ˙˙˙˙äň ›bývDxC‡ţ˙˙˙‡»÷vçÄřvň Ś+ 8parameter ń ż@ň ›bývÜL‡ţ˙..\rockdev\parameter er(L)_V1.11.bin Ěň ‡»÷v2¦ń Hň śń \ň `ň ›bývDxC‡ţ˙˙˙ň çÄřvň ň Í«şÜň »÷vň E Ś+ ň ÍřvŘývţĹřvPň Ľ»÷v‡»÷v„1¦ń Ěň ň ˙˙˙˙äň ›bývDxC‡ţ˙˙˙‡»÷vçÄřvň Ś+ 8misc eter ń ż@ň ›bývÜL‡ţ˙..\rockdev\Image\misc.img _V1.11.bin Ěň ‡»÷v2¦ń Hň śń \ň `ň ›bývDxC‡ţ˙˙˙ň çÄřvň ň Í«şÜň »÷vň E Ś+ ň ÍřvŘývţĹřvPň Ľ»÷v‡»÷v„1¦ń Ěň ň ˙˙˙˙äň ›bývDxC‡ţ˙˙˙‡»÷vçÄřvň Ś+ 8kernel er ń ż@ň ›bývÜL‡ţ˙..\rockdev\Image\kernel.img 1.11.bin Ěň ‡»÷v2¦ń Hň śń \ň `ň ›bývDxC‡ţ˙˙˙ň çÄřvň ň Í«şÜň »÷vň E Ś+ ň ÍřvŘývţĹřvPň Ľ»÷v‡»÷v„1¦ń Ěň ň ˙˙˙˙äň ›bývDxC‡ţ˙˙˙‡»÷vçÄřvň Ś+ @ 8boot l er ń ż@ň ›bývÜL‡ţ˙..\rockdev\Image\boot.img g 1.11.bin Ěň ‡»÷v2¦ń Hň śń \ň `ň ›bývDxC‡ţ˙˙˙ň çÄřvň ň Í«şÜň »÷vň E Ś+ ň ÍřvŘývţĹřvPň Ľ»÷v‡»÷v„1¦ń Ěň ň ˙˙˙˙äň ›bývDxC‡ţ˙˙˙‡»÷vçÄřvň Ś+ € 8recovery ń ż@ň ›bývÜL‡ţ˙..\rockdev\Image\recovery.img 11.bin Ěň ‡»÷v2¦ń Hň śń \ň `ň ›bývDxC‡ţ˙˙˙ň çÄřvň ň Í«şÜň »÷vň E Ś+ ň ÍřvŘývţĹřvPň Ľ»÷v‡»÷v„1¦ń Ěň ň ˙˙˙˙äň ›bývDxC‡ţ˙˙˙‡»÷vçÄřvň Ś+ 8system y ń ż@ň ›bývÜL‡ţ˙..\rockdev\Image\system.img g 11.bin Ěň ‡»÷v2¦ń Hň śń \ň `ň ›bývDxC‡ţ˙˙˙ň çÄřvň ň Í«şÜň »÷vň E Ś+ ň ÍřvŘývţĹřvPň Ľ»÷v‡»÷v„1¦ń Ěň ň ˙˙˙˙äň ›bývDxC‡ţ˙˙˙‡»÷vçÄřvň Ś+ 1 8backup y ń ż@ň ›bývÜL‡ţ˙..\rockdev\Image\update.img g 11.bin Ěň ‡»÷v2¦ń Hň śń \ň `ň ›bývDxC‡ţ˙˙˙ň çÄřvň ň Í«şÜň »÷vň E Ś+ ň ÍřvŘývţĹřvPň Ľ»÷v‡»÷v„1¦ń Ěň ň ˙˙˙˙äň ›bývDxC‡ţ˙˙˙‡»÷vçÄřvň Ś+ €
I tried the 0.92, and it is great, very fast and stable, the only problem is that I do not work the wi-fi and bt. Bt it does not matter, but the wi-fi matter to me. I have a T-R42 V2.0, and I tried to flash all kernels, but there anybody that active wi-fi and bt. Someone who can help me kindly?
There are currently 2287 users online. 5 members and 2282 guests.
