Pipo M6 Pro RileyROM 1.7 KitKat
    Finally, a working KitKat ROM for the M6 Pro!!!!!!!
    This ROM is based on firmware provided by manao in the 1.6 thread, post #54.
    I have tested this ROM to the point that I know that it boots, and is rooted. Wifi works. I have not encountered any problems with installing and running apps after a Titanium restore. So, I'm ready for you guys to take this for a spin.
    IMPORTANT FACTS
    1. You MUST flash the RK3188Loader(L)_V2.08.bin the first time you flash this ROM. KitKat requires this new loader to run. If you choose to go back to Jellybean...you MUST flash the loader for that ROM. The loaders aren't interchangeable.
    2. NONE of the files in a KitKat ROM are backward compatible with Jellybean files...so you can't use an OC kernel from my Jellybean ROM with this ROM, or you will not boot.
    This ROM has all of the features of 1.6:
    Rooted
    Not much to debloat
    Init.d support
    Busybox support
    English Language
    Google Play Store fixes
    VPN support
    2, 4, 6, 8, 12gb user app space choices (default 4gb)
    Multi-user support turned on
    Latest Reboot app by Petrus
    Boot Animation by Tattman65
    Updated First Time User's Guide
    RkBatchTool included as an alternate way to "switch" to flash mode
    New RK Driver Installer app
    Download
    Enjoy!!!!!!
    If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com
    Donate!!! Your donations keep me updated with the latest tablets to test on.
    Randy
    Fantastic. Thank you very much Randy.
    Wysłane z mojego HTC One przy użyciu Tapatalka
      But it is without GPS-support, is it?
      Gesendet von meinem Smartphone via Tapatalk
        wi fi power
        Hi!
        Randy, will you make version of this rom with wi-fi power changed up to 100%?
          cool! flashing from linux?
          This is so cool, I would like to try but my PC is running on Linux....
          is there a way to flash from linux like for instance with http://flashrom.org/Flashrom ?
          thanks for your great work!
          Victor
              I confirmed...no GPS support on this ROM. Maybe they had trouble with it, and left it out for now. There's a good excuse for an update, soon.
              Randy
                Originally posted by anavrin View Post
                Hi!
                I'm looking for those settings...I don't know what they have it set to by default.
                EDIT: They have it set to 80%
                If I do another update, I will increase it to 100%. Just try the current wifi settings and see if we really need the added 20%. My wifi seems very strong at 80%.
                Randy
                  So far, I'm very pleased with performance of this ROM.
                  Antutu score is 19570
                  Randy
                    It sounds really good, so i´m going to try it!
                    Thanks Randy!
                      Working fine and smooth.
                      Thx Riley
                      Sent from my M6 using Tapatalk
                        multiuser is not working on my pipo RileyRom 1.7, although the fw_maxusers.. entry is added in the build.prop
                          Looks like we need to find a new way to activate the feature...or it just simply isn't there anymore.
                          Randy
                            Sorry for asking again: Does GPS work properly with RR1.7?
                            Thank you for a short info.
                              No, GPS isn't active with this firmware. Also 3G isn't active.
                              Randy
