Pipo M6 Pro RileyROM 1.7 KitKat
    The problem is solved!
    I can reset the tab with the Volume+Esc+Power button and flash the rom again. Maybe the cable sliped out during the flashing process. So it was my fault actually.
    However your rom is amazing Riley! Its run more faster and smoother then the factory rom.
    Thank you for your work and your help! Good to know that there are people like you who working to android is getting better and better.
      Connecting my otg cable doesn't seem to work properly.
      After connecting a mouse, for instance, android tells me that sd-card can be removed or my browser window is refreshing (and deleting all my words I wanted to share in this forum ).
      So if the Big-Pipo-Brother reading this, he knows what to do ....
        You've got me on that one...I've never seen that.
        Sent from my SAMSUNG-SGH-I537 using Tapatalk
        Randy
          that's alright, with Big-Pipo-Brother I actually meant the Pipo company.. You, Randy, are more like a freelance-Pipo-uncle (well, if you're male)
          Joke aside,
          another experience: My bluetooth keyboard is running fantastic with Quickoffice compared to Android 4.2.2, where the delay of the letter recognition made it nearly impossible to use.
          Another Q: In my location service there are some options indicating the usage of GPS. I suppose it is just implemented for final Kit Kat releases and not working yet, isn't it?
          PS: About the 3G...l it is still showing up and I got about 200kb/s broadband connection... Could someone verify or falsify that 3G is working as mentioned in early posts of this thread?
            After instaling 1.7 in my m6 pro 3g i had a problem with wifi (always searching and never finds anything).When back to 1.6 everything went back to normal.Today i have instaled 1.7 and noticed that when i switch on wifi AND bluetooth, the wifi seems to work OK.Go figure!Just something for someone that has the same problem.
              I switched runtime back to dalvik to stop the 63 or so apps re-optimizing on every boot, I don't think it's fully art compatible yet.
              Sent from my Pipo M6Pro using Tapatalk Pro and RileyRom 1.7 KitKat test rom
                You wouldn't happen to have a micro SD card installed would you? I found this happening to me when I had a fat 32 formatted card. Formatting to NTFS removed the issue for me.
                  for me updates continue even without any microSD inserted.
                  It is very annoying
                    Re: Pipo M6 Pro RileyROM 1.7 KitKat
                    I do have a 32Gb card but it's already NTFS. One thing I haven't tried yet is to flash again and not use any backups but install all apps fresh. Other than that though it's been very stable and I'm happy with it's performance as a daily driver.
                      Guys, what about deep sleep on this Rom? My pipo with 3g but without SIM card work on 312 always(
                        this rom has the same issue of previous version: no deep sleep working for 3G models....
                          The problem that I have, is, if I set in "screenshot setting" the external SD, the pictures doesn't keep it.
                          I have to set to nand flash in order to keep the pictures.
                          The message is: "Couldn't save the picture. Storage may be in use".
                          Also, pictures of the camera (back or front), are saved into internal_sd.
                          Yes, the Pipo detects the external SD, and I can navigate it with explorers as well.
                            I think Android is expecting to see external storage at /storage/sdcard1 but Pipo is still using the older path of /mnt/external_sd and doesn't have a symlink
                              zvezdopad , on my PIPO M6pro W deepsleep working very well.
                                Help with flashing
                                Hi!
                                I am looking for some help with flashing Rileyrom.
                                My computer must have installed some drivers earlier. Because when I follow the First time user guide and click "reboot to flash mode" in Rom_flash_tool_137 it can't do anything. I get an error and am stuck.
                                I've read that it says that I woun't be able to flash it with my computer... or something like that.
                                When I manually put the tablet in flash mode (volume + and power) my computer reacts with "A unknown usb-device". When I get that message I try to install the drivers. Rightclick in Devicemanager and point it to the correct Drivers. But it fails.
                                Can someone give me some advice please! It would help me alot. Any developer who can help me out? Anyone who has had the same problem and can point me in the right direction?
