I'm confused...
Pipo M6 Pro RileyROM 1.7 KitKat
I cannot install TB APK, neither with ART nor with dalvik!
I'm confused...if you appreciate my efforts this is the link for any donation:
Originally posted by jsager View PostI noticed with Rayman Fiesta Run and Inotia 4 that there is an echo effect with the sound. It happens under both Davlik and ART runtime so it isn't the runtime that is causing it. This echo effect doesn't happen with Aces of the Luftwaffe and Zenonia 3 so it seems that some games aren't playing nice with KitKat on this tablet. I know this is all new so I don't expect perfection out of the gates. I also know that this rom was made for the M6 and not the M6 Pro which might be a factor (not sure what the difference is between the 2 tablets internally). Anyway, I am putting this out there just to see if anyone is experiencing the same issues. All else seem okay (except for the other known issues, of course).
Yep.. as I wrote in earlier post, I too experience some echo effect in for example Tiny Death star. But Candy Crush Saga, Fruit Ninja, Angry B etc works fine
Cheers
Re: Pipo M6 Pro RileyROM 1.7 KitKat
Originally posted by Kimmen View PostYep.. as I wrote in earlier post, I too experience some echo effect in for example Tiny Death star. But Candy Crush Saga, Fruit Ninja, Angry B etc works fine
Cheers
Sent from my Galaxy Nexus using Tapatalk
Originally posted by nodabble View PostI've just flashed. Will let you know about TB on mine.
Fast, but still Beta...
Today I installed RR1.7 as a test, after my test I went back to 1.6.1.
My findings:
- auto-rotate does not always work,
- much of the widgets I was using do not work (may be the widgets though)
- I wonder if the screen-layout (size, resolution) is working properly.
Icons are big, spacing is wide....
Anyway, I will test the next RR release again as soon it is available!!
Un saludo,
Satbeginner
Originally posted by Satbeginner View PostToday I installed RR1.7 as a test, after my test I went back to 1.6.1.
My findings:
Un saludo,
Satbeginner
[QUOTE=rrileypm;128712]There must be a slight variation with your hardware that is causing this...
Did you erase IDB before you flashed?
Is there an app you are running giving you problems?
may be its some kind of hardware problem because
i have flashed it twice but the results are same.
yes i have erased the idb both times.
no not an app all the work i do like open browser
go to setting etc reboots it
any way thanks for your help
Did you have the same problem with 1.6? You can flash back to it. Just be sure to check the loader.bin at the top of the flash tool.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Originally posted by rrileypm View PostDid you have the same problem with 1.6? You can flash back to it. Just be sure to check the loader.bin at the top of the flash tool.
my mistake i flash the rom 1.6.1 without ticking loader.bin
now tab doesn,t starts it stucks at recovery screen
is there any solution for this?
no there was no problem with 1.6.1 that is very smooth
i know i am a noob so please forgive me
Open the flash tool.
Connect the tablet.
Check the loader box on flash tool.
Press and hold escape button and press and hold power button until flash tool shows loader mode.
Wait about 10 seconds.
Click erase idb.
When it is done...flash the 1.6 ROM.
There are currently 1553 users online. 0 members and 1553 guests.
