Sent from my ZP990 using Tapatalk
Pipo M6 Pro RileyROM 1.7 KitKat
ART is definitely unusable...
every power on lasts 10 minutes because of the "app optimization"(CPU stuck at 1.2Ghz for 10minutes),
I tried different solution to install apps:
- from a titanim backup: app optimization at every boot
- from play store: same result
- from single APK files: same result
At the moment it is far better to use Dalvik, unfortunately...
Some kernels working on JB, in kitkat are not completely stable.
I used my Low_voltage kernel on EVERY Jelly Bean release, now with KitKat that is not stable at all. To test Kitkat better I needed to revert back to stock Kernel.
I need to check where is the problem...
With CPU spy I've noted that with Kitkat the CPU spend a lot much more time at maximum frequency with respect to Jelly Bean. Even when is not required (no app opened).
Jelly Bean used more 816Mhz for CPU.
This is not good for battery saving.
In general use Kitkat is faster and more responsive than Jelly Bean, It is very good and promising for a beta release.
With KitKat is not possible to charge the tablet from off condition: in that condition the tablet switch completely on (as on the very first release of Jelly Bean 4.2.2).if you appreciate my efforts this is the link for any donation:
Re: Pipo M6 Pro RileyROM 1.7 KitKat
Originally posted by greko2009 View PostGuys I have a problem with 1.6 (it happened in previous roms too) , sometimes (NOT always) if I hide the bottom bar then it doesn't appear again even after a reboot and the only solution is to re-flash ROM, how can I make it appear again? (touch drag from bottom doesn't work)
However you can install GMD gesture, it is a really good app but i don't like it.
P/s : in KK, how to hide the bottom bar? It will reduce Antutu marks during testing (decreased resolution i guess)
Originally posted by ninjakura View PostIt works actually if you continously drag the bottom bar. It is really irritating and that's why i changed to KK.
english please!!!!!if you appreciate my efforts this is the link for any donation:
Originally posted by cpasdupipo View PostBonjour
je travaille avec Windows 8.1 ,je n'arrive pas à installer les drivers de ma PIPO M6 PRO ,y aura t'il une solution un jour .Merci
Sent from my m6pro running Riley ROM 1.7 KitKat
Originally posted by levicius View PostGuys,my HDMI isn't working , any ideas if this is a kk issue or it may be a pipo issue ? I havent tried HDMI before flashing to kk .
Sent from my Nexus 7 using Tapatalk
Originally posted by cheddardonkey View PostWowee! Thank you Randy and Giouncino, with the 1.7 kitkat and modified kernel I'm running a solid 20,799 Antutu, you guys rock!
There are currently 1818 users online. 1 members and 1817 guests.
