Sent from my SAMSUNG-SGH-I537 using Tapatalk
Pipo M6 Pro RileyROM 1.7 KitKat
See my reply in the 1.6 thread. No need to double post.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Re: Pipo M6 Pro RileyROM 1.7 KitKat
Originally posted by giouncino View PostFor WiFi models only, deep sleep worked from the first Jelly Bean version.
As I said, this is a problem for 3G models...
Sent from my ZP990 using Tapatalk
I'm pretty sure it has to do with the modem running all the time.
Originally posted by rrileypm View PostI'm pretty sure it has to do with the modem running all the time.
I asked Anna Ye about this issue MANY times without success, I asked to pipowolrd.com customer care too...same wasting of time...
Now KitKat still shows the SAME issue. I have no words for this stupid behaviour....
When the tablet is connected on wi-fi or is in airplane mode I cannot understand why 3G service should be still running!!!! I think it is not so difficult to add these conditions to enable or not 3G service....if you appreciate my efforts this is the link for any donation:
Sent from my M6pro using Tapatalk
Originally posted by nutte View Postno deepsleep problems here on the 3g model aswell
are you REALLY sure?
Do you use the RileyRom 1.7 Kitkat?
How do you see that the tablet goes in deep sleep? Do you use Cpu Spy?
It is important to share with us these information,
thank you in advance.if you appreciate my efforts this is the link for any donation:
My (No)-Deep Sleep expierience is this:
Turning Pipo off for some hours --> when turning on again, battery percentage hasn't changed but after 5 Minutes, or so, of using the Pipo the percentage drops about 10 % ( probably depending on the time of hibernation) --> Therefore feel that I got tricked into believing it works... Hope it helps with the matter...maybe someone could check if I'm telling crap here
To have the PROOF that deep sleep is working or not:
- switch on the tablet
- install CPU spy
- leave the tablet on, wait untill screen goes automatically off
- wait 5 minutes (more or less)
- switch on the display and verify if on CPU SPY the row of deep sleep is present or not. If NOT deep sleep IS NOT working.
For 3G models with this KitKat beta ROM deep sleep row IS NOT PRESENT!if you appreciate my efforts this is the link for any donation:
For deep sleep you can also look at the thin blue line immediately below the battery graph. Where the line is broken the tablet is sleeping. If you have sync enabled for some apps the tablet will wake very briefly periodically. I also found that you can leave airplane mode on and still turn on WiFi when you want it (it will override airplane mode) which is strange but apparently even iPhones do that.
Sent from my Pipo M6Pro using Tapatalk Pro and RileyRom 1.7 KitKat test rom
Also this graph could not be accurate, the BEST way to be SURE if deep sleep is working is using CPU SPY.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostAlso this graph could not be accurate, the BEST way to be SURE if deep sleep is working is using CPU SPY.
There are currently 2160 users online. 0 members and 2160 guests.
