Before I flash a new rom I do it once more and after the new rom is installed I click on "restore all user apps+system data". Is this right or should I do it as Randy says ?
Pipo M6 Pro RileyROM 1.7 KitKat
One question about Titanium back up. I usually click on “Backup all user apps + system data" and I do it over and over again when I install new apps or do any changes in my tablet.
I can confirm this works with sumvision 2 9.7 if any wants to try and here a link to original firmware i got from sumvisions tec support http://www.mediafire.com/download/rs...ager+2+9.7.rar if want to go back thanks for the rom rrileypm
Originally posted by spawnofdonny View PostI can confirm this works with sumvision 2 9.7 if any wants to try and here a link to original firmware i got from sumvisions tec support http://www.mediafire.com/download/rs...ager+2+9.7.rar if want to go back thanks for the rom rrileypm
Cheers it's good to know. Thanks for the original FW too even though I have no idea why anyone would ever want to go back to that!
Originally posted by at00 View PostYesterday i tried to reboot my m6 pro in recovery mode, now i can't escape from the cmw recovery menu, i press reboot recovery but it always enter in the cmw, i'm desperate. the bacth tool don't detect the device. someone help me
Re: Pipo M6 Pro RileyROM 1.7 KitKat
Originally posted by GeorgeKa View PostOne question about Titanium back up. I usually click on “Backup all user apps + system data" and I do it over and over again when I install new apps or do any changes in my tablet.
I always restore missing apps with data. This selection only restores the apps you select to restore...with only the data associated with those apps.
Doing it this way...you have a better chance of keeping the grimlins out.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Originally posted by spawnofdonny View Postits ok we just have to wait for a cwm update
KitKat has introduced a new metadata partition that has not appeared in Jellybean. It took me a while to find it.
In order to use CWM to make NAND backups again...we need a KitKat compatible version. I have looked and can't find an adjustment. The CWM binary within recovery.img must be rewritten for this.
Maybe Fun or another CWM developer will put out an update soon.
I went ahead and included CWM with this ROM because I thought we could still use some of the other features...like installing apps from SD card. I haven't tested it to see what still works and what doesn't.
Please post your experiences with the other features here.
We are still discovering new things about KitKat together...so please report your findings. We are all beta testers at this point. And I have a feeling that Pipo IS watching........
So if some PIPO guys are reading, here are some issues I've found:
- DEEP SLEEP for 3G models also with KitKat STILL doesn't work (old errors are hard to loose...)
- I switched on ART after the TB restore and now every power-on remains for 10 minutes in "optimising system" for 61 apps. I supposed it is performed only once, but this happens EVERY boot... It also mantains CPU at 1.2Ghz for 10 minutes...
- Sometimes during optimization the tablet just freeze. I needed to use the reset and wait another 10 minutes for power-on.
- Rotation of the screen is not so fast...
- Scrolling of pages (for example settings) is a little laggy
- Some apps doesn't work: Faster GPS and AdAway for example doesn't work any more.
- To reduce the brightness under minimum I used an app called "screen filter": with this rom if I enable it, general perfomance decrease dramatically!
- It happens once a reboot of tablet during browsing.
All happened with stock Kernel. I used my modified kernel until the first problem, than I reverted back on stock kernel, but nothing has changed. So the problem is due to the "BETA" status of this release.
Of course none of the previous problem were present on latest Jelly Bean ROM.if you appreciate my efforts this is the link for any donation:
Thanks for the report!!!!!!! Good to know.
By chance, is your external SD formatted FAT32 or NTFS? I have not encountered a lock up, yet...and my external SD is NTFS.Randy
Originally posted by rrileypm View PostThanks for the report!!!!!!! Good to know.
And, Randy, sorry to ask you again: could you please post the stock bootanimation.zip for 4.4.2?if you appreciate my efforts this is the link for any donation:
If any is trying ART have look at this list first http://www.androidruntime.com/list not all apps are work yet
Adaway is working fine for me have you tried clearing the app data from adaway and update it again i had a similar problems with my galaxy s2
There are currently 2289 users online. 3 members and 2286 guests.
