Sent from my ZP990 using Tapatalk
Pipo M6 Pro RileyROM 1.7 KitKat
Originally posted by cpasdupipo View PostI have not found or ART activate or activate you.Thanksif you appreciate my efforts this is the link for any donation:
Re: Pipo M6 Pro RileyROM 1.7 KitKat
Originally posted by giouncino View Postyou can activate art on "options for developers". But pay attention, if you have many installed apps. Boot time could be very long, because of the every boot optimizations!
So far, we haven't been able to activate the feature on the KitKat ROMs. It's either a different setting or simply excluded.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
The Stock rom of m6 pro had this so called settings in "display" to switch the HD Screen to normal which is From Retina to Normal Display. if you switch to normal the performance of the tablet will greatly increase for example there will be no Lag and stuff. and also it will be smoother. Now I'm wondering if where did the setting go ? Please kindly put it back. because seriously our M6 Pro is on RETINA DISPLAY And there's no function to put it back to normal and that causes the slow performance of the tablet.
Thanks!
Originally posted by kirkyang View PostThe Stock rom of m6 pro had this so called settings in "display" to switch the HD Screen to normal which is From Retina to Normal Display.
Which firmware has the option to change from Normal to HD? I'm using RR 1.5 and I really feel a less batery life.
Could you add un the next firmware that option please?
Tank you forma tour effort Riley!!
1.4.2 is the last firmware with that capability
Originally posted by manao View PostLook at this: http://www.freaktab.com/showthread.p...l=1#post127513
Originally posted by kirkyang View Postokay but the ro.rk.resolution_enable=false in the build.prop is not there on 1.7 kitkat. all i can see is ro.sys.resolution_change=false
Sent from my m6pro running Riley ROM 1.7 KitKat
Originally posted by ajvill View Postdoes anyone have the link to that modified kernel?
sorry, i lost track of the thread. wanted to try it.
Don't plan on anything new from Pipo for a few weeks...anyway. Nothing gets done in China this time of year.
There are currently 1829 users online. 0 members and 1829 guests.
