- fixed A2 airmouse sound issue
- added support Multiple usbflash disk and Multiple partition
- added support auto frame rate switching
- updated google apps
- fixed more sound issues
- improved the system stability
kernel download: kernel-cpu1800-gpu798-ddr800.7z
Version 3.0.5
- fixed the crash in ion driver which causes many video files cannot be played (only black screen)
- fixed critical issue in Bluetooth setting which causes a system reboot
- added SPDIF passthrough support
- enable watchdog support
Version 3.0.4
- fixed random crashes
- fixed HDMI issue which causes black screen when unplug the HDMI cable
- dropped es file manager, added rkexplorer as replacement
- fixed some audio issues (i don't have hardware equipment to test hdmi passthrough, please test yourself and report feedback with log files)
- fixed HDMI flicker by 1080p60hz
- add support 40 inch philips lcd monitor (PHL BDM4065)
Version 3.0.3
- added rotation support
- added support for netflix and amazon prime video
- fixed issue in root/unroot device
- fixed the issue in ir-remote (HOME-button works fine now)
- fixed some sound issues
Version 3.0.2
- fixed several crashes
- added support deinterlacing
- added support for RKMC
Version 3.0.1
- add screen scale
- HW acceleration full support
- add swiching HDMI resolution
- fix some sound issues
- improve video streaming and UI system
- add support for wifi 5Ghz
- add menu to root/unroot device
Version 3.0.0
- firmware based on lollipop 5.1.1
- support HDMI sound, SPDIF and HDMI Bitstream
- ir-remote support
- support ethernet
- support wifi
- support bluetooth
- support LED
- init.d support
- unified single partition
- sdcard support
- webcam support
- nfs filesystem support
- ntfs filesystem support
- exfat filesystem support
- iso/udf filesystem support
- xposed support
- added hide/show navigation and statusbar
- added poweroff button in navigation bar
- added softreboot, reboot in recovery and bootloader
- added "clear all recent apps" button
- add support hdmi virtual switch
- multiuser support
- root device
- A2 Airmouse support
- hardware keyboard support
- lock screen support
- add latest google apps
- added menu option for "Connect to PC"
version 2.0.3
- fixed multi partition mount issue
- fixed google play music silent issue
- fixed "sound output options don't save on reboot by using usb sound device like SAGE AirMouse" issue
- removed VPN PIN request
- improved ethernet driver r8152
- fixed issue in usb audio devices routing
oc-kernels:
kernel-neox7-wasser-cpu1800-ddr800-gpu798
kernel-neox7-wasser-cpu1800-ddr800-gpu798-hdmi_flicker (only used if you have screen flicker!)
stock-kernels:
stock-kernel-neox7-wasser
stock-kernel-neox7-hdmi_flicker-wasser (only used if you have screen flicker!)
version 2.0.2
- based on the new version of the SDK
- firmware now based on release-keys instead of test-keys to improve app compatibility
- LAN performance improvement
- fix some security issues
- exfat file system support
- auto mount exfat/ntfs/ext4 filesystem
- add menu for locationsetting
- UI, video streaming, stability improvement
- add 1080p youtube support
- add amazon instant video support
- add new poweroff dialog, reboot to bootloader, recovery mode
- add longpress menu key to show/hide statusbar
- hide statusbar by default
- add new wallpaper and mouse pointer
- fix write capability to external SD card
- fix contacts & calendar sync issue
- fix some issues in Launcher3
- busybox up to date
- add ability to root or unroot device per recovery
- add ability to update FW per recovery
- google apps updated
update-stock-kernel-neox7-wasser
updates:
fix multi partition mount issue
root wasser firmware
unroot wasser firmware
fix google play music silent issue
WARNING: previous oc-kernels doesn't work with new firmware 2.0.2
version 1.0.4
- included all features/fixes from previous release
- internal mic support
- added localation setting
- 16gb in one partition
- fixed a bug in hardware keyboard setting
- several fixes which i don't remember
- wasser xbmc 1.2
- improved hdmi driver, system stability
wasser xbmc: http://www.freak-tab.de/wasser/wasser-xbmc-v1.3.apk
version 1.0.3a
- included all features/fixes from 1.0.3
- fixed critical permission issue for external/internal storage
- fixed otg port issue
- added google voice support
wasser xbmc: http://www.freak-tab.de/wasser/wasser-xbmc-v1.2.apk
please use RKBatchTool to flash the new firmware
oc-kernels-1080p: http://www.freak-tab.de/wasser/oc-ke...x-x7-1080p.zip
kernel-720p: http://www.freak-tab.de/wasser/kernel-minix-x7-720p.zip (warned, before you flash this 720p kernel you have first to change ro.sf.lcd_density=240 to ro.sf.lcd_density=160 in /system/build.prop, otherwise it won't boot correctly!)
version 1.0.3
- preload wasser xbmc-1.1 based on gotham 13.1 stable release
- passthrough support in wasser xbmc
- add setting for Accessibility
- add setting for sleep, daydream and wallpaper
- add support for Mouse Wheel Zoom Settings
- add support for no wakup on mouse movement, enable it by default
- add manual hide system bar, you can wipe from bottom/top of screen to show it again
- add setting for Alarm/Notifications volume
- add support hls streaming
firmware: wasser-firmware-kikat-minix-x7-1.0.3.zip
wasser xbmc: http://www.freak-tab.de/wasser/wasser-xbmc-v1.1.apk
version 1.0.2
- fixed regression in kernel which caused random crashes
- fixed red frame issue in chrome browser
- added option to disable the hardware keyboard
(add ro.hardkeyboard.support=false to /system/build.prop to disable hardware keyboard )
firmware: wasser-firmware-kikat-minix-x7-1.0.2.zip
wasser xbmc: http://www.freak-tab.de/wasser/wasser-xbmc-v1.0.apk
version 1.0.1
- fix bootloop issue when static ip is set for ethernet
- include all features/bug fixes from 1.0.0 release
Link download: wasser-firmware-kikat-minix-x7-1.0.1.zip
version 1.0.0
- perfect 1080p fullhd video streaming
- multiuser support
- usb webcam support
- autohide status bar
- multi usb partitions support
- google apps up to date
- google searchbar is disable by default
- screen rotation support
- enable tun in the kernel
- notifacation sound support
- reboot/sleep/bootloader mode dialog
- init.d support
- ir-remote, A2 Airmouse support
- cwm recovery support
- ntfs, nfs, cifs filesystem support
- rooted
changes between 0.95-1.0.0 release:
- add dialog for reboot,sleep,reboot in bootloader mode
- add multiuser support
- add autohide statusbar and enable it by default
- use 6g parameter
- fix issues a2 airmouse: wrong keymapping, soundoutput reset to default by next reboot
- fix issue in usb webcam with dark image
- fix blue light issue
- several another fixes which i don't remember
Link download: wasser-firmware-kikat-minix-x7-1.0.0.zip
version 0.95
- update busybox
- update google apps
- add hardware keyboard
- restore screen scale setting works now
- add lock screen
- make Google Launcher3 as default Launcher
- remove nova launcher
- remove google searchbar
- add screen rotation
- add notifacation sound
Link download: wasser-firmware-kikat-minix-x7-0.95.zip
OC-kernels: oc-kernels-minix-x7.zip
version 0.94
- kikat 4.4.2
- sound device manager
- wifi support
- ethernet support
- bluetooth support
- ir-remote support
- init.d support
- rooted
- ntfs, nfs, iso, cifs filesystem support
- preinstall es file manager
- nova launcher
- cwm recovery
- added 1080p24hz, 1080p30hz
Link download: wasser-firmware-kikat-minix-x7-0.94.zip
version 0.92
- Ugoos Ut1, k-r42, t-r42 and minix x7 (please select the correct kernel)
- kikat 4.4.2
- wifi support
- ethernet support
- init.d support
- rooted
- preinstall es file manager, reboot
- cwm recovery
- added 1080p24hz, 1366x768p60hz support
Link download: firmware-wasser-0.92-4.4.2.zip
parameter files (thanks to 900supersport)
new kernels fix ethernet, wifi, bluetooth, ir-remote issue:
kernel-neox7-720p.zip
kernel-neox7-1080p.zip
oc kernels (only work in 0.92):
CPU: 1008/1200/1416/1608/1800, DDR: 720, GPU: 400/600
kernel-minix-x7-160114.zip
CPU: 312/504/816/1008/1200/1416/1608, DDR:720, GPU: 133/200/266/300/400/600
kernel-1080p-ddr720.zip
CPU: 1008/1200/1416/1608/1704/1800, DDR:720, GPU: 133/200/266/300/400/600, 1080P
kernel-ddr720-cpu1800h-1080p
CPU: 1008/1200/1416/1608/1704/1800, DDR:720, GPU: 133/200/266/300/400/600, 720P
kernel-ddr720-cpu1800h-720p
cpu1704h/cpu1800h gpu798h ddr800 1080P, cpu1704h/cpu1800h gpu798h ddr720 1080P
cpu1704h/cpu1800h gpu600h ddr720 1080P, cpu1704h/cpu1800h gpu600h ddr800 1080P
oc-kernels-1.zip
