3 if i remember correctly you can change it in build.prop
Originally posted by wasser View Postit's exactly what i need. Thanks again!
i need the same again but with my kernel + my rom
Edit: the sound increase/decrease bug is back, 0 to 100 on a single click.
Just wanted to also add, while i was helping Wasser flashing several times the kernels, i havent had a single bad experience with crashes or as i mentioned before, browser mess which mostly shutdown/restart my device.
Then i had to test stock 008 and extract some useful logs, while doing that, i had at least 2 restarts.
I seriouslty cant deny the cirsspyness the rom has, we're really really lucky.
Guest
Just tried 110114-1 kernel and still no ethernet. see attached dmesgAttached Files
Originally posted by soyrme View PostJust tried 110114-1 kernel and still no ethernet. see attached dmesg
thnx for helping as well mate, your tip to boot into flashing mode saved me a lot of hassle, as it seems everyone downgrading will face a bit of resistance.
Originally posted by Pluto View Postprevious kernel fixed the remote, confirmed, but it broke the sound buttons increase/decrease again, can you check that? just asking if wasser addressed that even though we're all focused on Ethernet.
thanks
Guest
Bugfinding
Hi all!
Currently on Holiday but can't wait to get my hands on this one. I'm really curious about this rom seeing as it 's purely based on the SDK release.
With the Minix firmware there are some strange bugs for me (remotes that cause shutdowns etc, unstable sound performance over USB).
When ethernet works I'll get my Raspberry Pi ready to take over the media duty's and go for a nice little bug hunt
Guest
Originally posted by wasser View Postthanks, could you please check if bluetooth works?
Bluetooth works. I paired with a jambox and was able to play a video with sound out of the jambox.
Volume up/down works properly with bluetooth connection. you can go through all the gradients of volume no problem.
Volume up/down is broken when you are outputing through the hdmi cable to the monitor still. When you press volume up, it goes to maximum only, vol down goes to zero volume only. Mute key doesn't seem to work. This is on a logitech k400r external rf/usb keyboard and the favi external rf/usb keyboard. I just realized that there is no sound output options like passthrough, hdmi, like in the standard x7 008 stock firmware.
Ethernet is not working as well.
EDIT: I saw you just posted 114-2 and will report back on that shortly
bluetooth was a mustfix for me, it's great that it's working!
sound output options like passthrough, hdmi are still missing in this kikat sdk
Guest
Originally posted by soyrme View PostOn 114-2
We have ethernet! I'm checking other items above now and will repost
thanks
There are currently 3631 users online. 1 members and 3630 guests.
